can i set a wireless AP that does not require a password by esp32?
when i not set wifi_config.ap.password,then function esp_wifi_set_config(ESP_IF_WIFI_AP, wifi_config) return err. and give me message "password less than 8".
Re: can i set a wireless AP that does not require a password by esp32?
What is WiFi Auth Mode you have selected? You can give without password if Auth Mode is Open I think.zhoupeng wrote:when i not set wifi_config.ap.password,then function esp_wifi_set_config(ESP_IF_WIFI_AP, wifi_config) return err. and give me message "password less than 8".
Regards,
Ritesh Prajapati
Ritesh Prajapati
Move news -> general discussion
thanks for you answer,I'm sorry to reply to you so late. I think it should be OK. Thank you.Ritesh wrote:What is WiFi Auth Mode you have selected? You can give without password if Auth Mode is Open I think.zhoupeng wrote:when i not set wifi_config.ap.password,then function esp_wifi_set_config(ESP_IF_WIFI_AP, wifi_config) return err. and give me message "password less than 8".
Most welcomezhoupeng wrote:thanks for you answer,I'm sorry to reply to you so late. I think it should be OK. Thank you.Ritesh wrote:What is WiFi Auth Mode you have selected? You can give without password if Auth Mode is Open I think.zhoupeng wrote:when i not set wifi_config.ap.password,then function esp_wifi_set_config(ESP_IF_WIFI_AP, wifi_config) return err. and give me message "password less than 8".
Let me know if need anything else or any help regarding ESP32
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: iucharbius and 243 guests
