a questions about burn mode
Zxc123456
Postby Zxc123456 » Wed Apr 17, 2019 3:17 am
I use the ESP32_Devkitc_V4 development board. Why the board is not in burn mode?I still can download th bootload core.I looked up information for esp32 datasheet. It say when board in burn mode the GPIO0 must be pull-down。So how do i know the GPIO0 status?
commando_j
Re: a questions about burn mode
Postby commando_j » Wed Apr 17, 2019 7:22 pm
On your kit, GPIO 0 is pulled up internally and has a button to pull down the IO when you need it.
Zxc123456
Postby Zxc123456 » Thu Apr 18, 2019 7:05 am
Thanks for your reply.My question is i'm not push the button.i still can download the core for the board.But the datasheet say's if you will download core the GPIO0 must be pull down.So i'm confused.
WiFive
Postby WiFive » Thu Apr 18, 2019 7:27 am
It also has a automatic boot mode circuit, check schematic
https://github.com/espressif/esptool/wi ... bootloader
Zxc123456
Postby Zxc123456 » Thu Apr 18, 2019 10:01 am
Many thanks for your advice. Such is the case.Have learned.
Users browsing this forum: Baidu [Spider] and 12 guests
