ESP32 + LAN8720 advice
Posted: Wed Jun 09, 2021 5:13 am
by artyomka71
Hi!
Help is required to connect the LAN8720AI-CP-TR to the ESP32 .
I built a scheme where LAN8720 is required, I took the Olimex ESP32-POE solution as a basis and read the information in the LAN8720 Datasheet . The final scheme is shown in the attachment. I ordered the board on jlcpcb, then I flashed it with ESPhome, but the Ethernet does not work :? . WI-FI works very well. I think that somewhere I have an error in the scheme, but I do not see it. Help me find the mistake in the scheme.
The ESPHome settings are as follows:
esphome:
  platform: ESP32
  board: esp-wrover-kit
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  power_pin: GPIO12
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.52
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
Olimex ESP32-POE https://github.com/OLIMEX/ESP32-POE/blo ... _Rev_E.pdf
Datasheet LAN8720 https://datasheet.lcsc.com/lcsc/1809291 ... C17146.pdf
