ESP32 WiFi goes OFF when output pin is continuously toggled
I'm having challenge with my ESP32 Dev board. Whenever I connect to wifi and try to trigger the output pin, everything seems to work fine except that the WiFi goes OFF at some point and does not come ON until I switch OFF and then ON the power supply. Anyone know what the problem is?
Re: ESP32 WiFi goes OFF when output pin is continuously toggled
Can you share code? What do you mean with 'wifi goes OFF', can you share serial logs when that happens?
I don't think the problem is with my code because everything works fine when plug ESP board to my PC. The problem only happens when I connect ESP board to my circuit to switch load. What I mean by WiFi goes OFF is that the WiFi network disappears completely and only reappears when I switch OFF and ON power supply.
Hello @chuxyz
you might need something like a snubber (https://en.wikipedia.org/wiki/Snubber) to reduce EMI. I had a similar issue where I could switch a relay by itself just fine, but some weird stuff started to happen when I attached a light bulb to the relay. Adding a snubber fixed the issue for me.
Felix
Felix
My circuit is a very simple one. Output pin of ESP circuit triggers a 5Vdc relay which in turn triggers a 220Vac relay that powers a single phase electric motor. I used a linear power supply to power ESP boardESP_Sprite wrote: ↑Tue Oct 19, 2021 12:53 amAh, you didn't mention that before. What circuit are you using, can you post a schematic, or at least tell us what components are involved?
Output pin of ESP circuit triggers a 5Vdc relay which in turn triggers a 220Vac relay that powers a single phase electric motor. I used a linear power supply to power ESP board.ESP_Sprite wrote: ↑Tue Oct 19, 2021 12:53 amAh, you didn't mention that before. What circuit are you using, can you post a schematic, or at least tell us what components are involved?
Thank you Felix.felmue wrote: ↑Tue Oct 19, 2021 8:06 amHello @chuxyz
Felix
Should the snubber be in parallel with relay contact or with the load?
Hello @chuxyz
In my case I used an RC snubber with is in parallel to the relay contact.
Please be careful when doing experiments with mains voltages.
Felix
Felix
Users browsing this forum: No registered users and 106 guests
