I am running my ESP32-D2WD at 1.8v
Looks like the FT2232H chip does not support 1.8v JTAG debugging.
Any recommendations for debugging the chip at 1.8v?
EDIT:
Looks like the Flyswatter2 supports 1.8v, must have level sifters inside?
JTAG debugging at 1.8v
Re: JTAG debugging at 1.8v
Like other variants of ESP32, ESP32D2WD is rated for supply voltages down to 2.3V.
Only the pins in VDDSDIO power domain of the ESP32D2WD work at 1.8V, the rest of the pins work at 2.3-3.6V.
JTAG pins are not in VDDSDIO power domain, so your JTAG adapter does not need to be 1.8V compatible.
dear hassan789,@ hassan789 I want to use the ESP32-D2WD, but it seems that my PCB has problem.so I was burning to know how the circuit diagram you make ? Would you give me a reply ?Thanks very much.
Best wishes .Daniel.
igrr,ESP_igrr wrote:Like other variants of ESP32, ESP32D2WD is rated for supply voltages down to 2.3V.
According to the latest ESP32 datasheet, both VDD3P3_CPU & VDD3P3_RTC can be power from 1.8v to 3.6. See attached..
Since the JTAG lines are in RTC domain, they should be 1.8v, if my understanding is correct. I am designing a board with all domains powered at 1.8v (except VDDA at 3.3v). Please Advise!
- domain.jpg (80.28 KiB) Viewed 9406 times
- rtc.JPG (129.84 KiB) Viewed 9407 times
Oh, apparently I was reading an older version of the datasheet. Sorry for the confusion.
FYI, a fair few other boards like the TUMPA also have level shifters inside. If you don't have one, maybe you can hack something up with a SN74LVC16T245 or a discrete set of resistive dividers on tck/tdo/tms plus a comparator on tdi.
since i am successful in jtag debug the eps32 wrover with open ocd , change the voltage value in esp32_xxx.cfg file to 1.8V , try.
looks like the problem with flyswatter2 is that the UART is 12v...
the TIAO USB Multi-Protocol Adapter (TUMA) claims to be 1.8v JTAG compliant, but the UART is either 3.3v TTL or 12v RS-232.
Users browsing this forum: No registered users and 68 guests
