Can't upload code to WROOM-32D
rubfergor
Postby rubfergor » Fri Aug 31, 2018 11:43 pm
I have designed a PCB using the ESP32 module, however I do have problems uploading code to it. When I power the board, I get the following message:
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
However, when I try to flash it, all that I get is:
$ make flash
Python requirements from C:/msys32/home/rubfe/esp/esp-idf/requirements.txt are satisfied.
Flashing binaries to serial port COM9 (app at offset 0x10000 )...
esptool.py v2.5.0
Serial port COM9
Connecting........_____....._____....._____....._____....._____....._____....._____
make: *** [/home/rubfe/esp/esp-idf/components/esptool_py/Makefile.projbuild:63: flash] Error 2
This happens both with IDF and with Arduino IDE.
The schematics of the module are attached and are made following the recommendations of design outlined in the ESP32 WROOM-32 module datasheet. The module in question is this. I'm supplying power through a 12V/2A power source (regulated by a LM1117T, which has a 800mA output and which remains in operating temperature). I'm using this FTDI cable to program it using UART. I have mixed success using it to program, as I have been able to program a DevKitC development board with it, but not another one (which is newer and I'm able to program using the microUSB connection).
Any help would be greatly appreciated. Thanks in advance!!
fovea1959
Re: Can't upload code to WROOM-32D
Postby fovea1959 » Tue May 21, 2019 4:06 pm
Did you get this resolved? I am having a similar problem with a DevKitC, which you indicate you had the issue with some units.
gecko242
Postby gecko242 » Thu May 23, 2019 10:49 am
You need a pull up on IO0 I believe.
Also, are you toggling the reset line?
Workflow should be:
Pull IO0 Low
Reset chip (or cycle power)
Release IO0
Initiate Download
cycle power when complete
Done!
Users browsing this forum: No registered users and 124 guests
