wifi_config_t structrue ap and sta members are overriten
Gasoile
Postby Gasoile » Thu Apr 19, 2018 3:53 pm
Hi, I'm starting a project with ESP32 using esp-idf and I'm getting some wierd behaviors when using wifi_config_t structures.
If I initialize the structure like this:
wifi_config_t wifi_cfg = {
  .ap = {
    .ssid = "TEST",
    .password = "TESTPASS",
    .ssid_len = 8,
    .channel = 1,
    .authmode = WIFI_AUTH_WPA2_PSK,
    .ssid_hidden = false,
    .max_connection = 1,
    .beacon_interval = 100
  .sta = {
    .ssid = "SCANN",
    .password = "SCANNPASS",
    .bssid_set = false,
    .bssid[0] = 0,
    .bssid[1] = 1,
    .bssid[2] = 2,
    .bssid[3] = 3,
    .bssid[4] = 4,
    .bssid[5] = 5,
    .channel = 0,
    .sort_method = WIFI_CONNECT_AP_BY_SIGNAL,
    .threshold = {
      .rssi = -127,
      .authmode = WIFI_AUTH_OPEN
and then print:
ESP_LOGD(HYPERION_WIFI_TAG,"WiFi Configuration:\n\tap:\n\t\tssid:%s\n\t\tpassword:%s\n\t\tssid_len:%u\n\t\tchannel:%u\n\t\tauthmode:%u\n\t\tssid_hidden:%u\n\t\tmax_connection:%u\n\t\tbeacon_interval:%u\n\tsta:\n\t\tssid:%s\n\t\tpassword:%s\n\t\tbssid_set:%u\n\t\tbssid:%2x:%2x:%2x:%2x:%2x:%2x\n\t\tchannel:%u\n\t\tsort_method:%u\n\t\tthreshold.rssi:%d\n\t\tthreshold.authmode:%u", wifi_cfg.ap.ssid,wifi_cfg.ap.password, wifi_cfg.ap.ssid_len, wifi_cfg.ap.channel, wifi_cfg.ap.authmode, wifi_cfg.ap.ssid_hidden, wifi_cfg.ap.max_connection, wifi_cfg.ap.beacon_interval, wifi_cfg.sta.ssid, wifi_cfg.sta.password, wifi_cfg.sta.bssid_set, wifi_cfg.sta.bssid[0], wifi_cfg.sta.bssid[1], wifi_cfg.sta.bssid[2], wifi_cfg.sta.bssid[3], wifi_cfg.sta.bssid[4], wifi_cfg.sta.bssid[5], wifi_cfg.sta.channel, wifi_cfg.sta.sort_method, wifi_cfg.sta.threshold.rssi, wifi_cfg.sta.threshold.authmode);
and the result I get is:
WiFi Configuration:
ap:
ssid:SCANN
password:SCANNPASS
ssid_len:0
channel:0
authmode:33619968
ssid_hidden:3
max_connection:4
beacon_interval:5
sta:
ssid:SCANN
password:SCANNPASS
bssid_set:0
bssid: 0: 1: 2: 3: 4: 5
channel:0
sort_method:0
threshold.rssi:-127
threshold.authmode:0
Note that the members from the member ap from wifi_config_t are affected by initializing the member sta. Does someone has similar problem? What am I missing?
Thanks a lot for any help.
Re: wifi_config_t structrue ap and sta members are overriten
Postby ESP_Sprite » Fri Apr 20, 2018 1:05 am
The .sta and .ap members are in an C union: they essentially map to the same bit of memory. This is because the ESP32 essentially has two virtual interfaces: one that can act as a station, one that can act as an access point. You can't configure one interface as both things, so the members can happily share the memory for the configuration options and save some memory.
Gasoile
Postby Gasoile » Fri Apr 20, 2018 9:20 am
Thanks a lot!
I had not realized it is union! It would be handy to have it as struct if you want to switch between modes or use APSTA mode. In my case I will not save some money because I need to keep track of both AP and STA configurations...
But now I can finally move one in peace :) .
Users browsing this forum: eriksl and 232 guests
