Modbus TCP Implementation
dkaufmann
Re: Modbus TCP Implementation
Postby dkaufmann » Fri Aug 28, 2020 8:51 am
okay thank you very much for your reply, very appreciated.
I am looking forward for the new version then.
best regards
DK
jas39_
Postby jas39_ » Sun Oct 18, 2020 6:37 pm
@ESP_alisitsyn,
Any update on when this feature can make it into the MASTER tree?
I'm implementing a TCP modbus slave with a very sparse register map and it would save mamory to be able to have several areas of each type
Rgds
/Anders
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Mon Oct 26, 2020 12:49 pm
@jas39_,
Unfortunately I can not provide the concrete date for this feature. It is in my todo list and will be implemented after higher priority tasks.
deolsunny533
Postby deolsunny533 » Tue Oct 27, 2020 10:31 am
Could you tell me little bit more about your application? Is this Modbus master TCP or slave?
dkaufmann
Postby dkaufmann » Wed Oct 28, 2020 8:09 am
in my case it is a Modbus TCP slave (server).
The problem is, that the prepared library from esp-idf does not allow several areas of holding register areas.
Users browsing this forum: No registered users and 46 guests
