HTTPS OTA error: Passive OTA partition not found
Posted: Sat Jul 20, 2019 3:40 pm
by RMandR
I have built and flashed my application using "make flash monitor" (windows 7, ESP_IDF 3.2).
The partition table is as below and I'm getting a "Passive OTA partition not found" after the call to
 esp_https_ota(&config)
What am I doing wrong?
Thanks in adance!
partition.csv
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x4000,
otadata,  data, ota,     0xd000,  0x2000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  0,    0,       0x10000, 1M,
ota_0,    0,    ota_0,  0x110000, 1M,
ota_1,    0,    ota_1,  0x210000, 1M,
output:
I (4706) esp_https_ota: Starting OTA...
E (4706) esp_https_ota: Passive OTA partition not found
E (4706) HTTP_CLIENT: Firmware Upgrades Failed
Re: HTTPS OTA error: Passive OTA partition not found
Posted: Mon Jul 22, 2019 1:27 pm
by RMandR
In case anyone else trips onto this: partition.csv is not read by default.
" choose “Custom partition table CSV” in menuconfig"
Posted: Mon Jul 22, 2019 7:01 pm
by Ritesh
Thanks in adance!
partition.csv
output:
Which Partition table you have selected for OTA example? Because as per error it seems like you are facing issue due to wrong partition table selection that is why OTA is going to fail due to that reason.
