Setting AP fixed data rate "wifi_phy_rate_t"
xtrmsound
Postby xtrmsound » Fri Aug 09, 2019 12:48 am
I am looking to find a way to set a fixed data rate when the esp is set as a softapi. However, I couldn't find any function in the API, or a code example, that provide an example how on the implement it. I browsed through the IDF API documentation, but I could only find the enum code, but not how to use it.
Any thoughts? Did anyone was able to implement it?
Thanks!
Re: Setting AP fixed data rate "wifi_phy_rate_t"
Postby rudi ;-) » Fri Aug 09, 2019 2:11 am
Thanks!
Hi
you find details in the ESP-IDF Programming Doc under wifi_phy_rate_t
Code examples for Wi-Fi are provided in the wifi directory of ESP-IDF examples.
Also perhabs you have a look to these post,
this should help for your settings.
hope this helps for read in.
edit: WiFive was faster :), did not see the answer
xtrmsound
Postby xtrmsound » Mon Aug 12, 2019 3:16 pm
Thank you!
It works!
This is how it complie and runs
#include "esp_private/wifi.h"
ESP_ERROR_CHECK(esp_wifi_start());
wifi_interface_t ifx = WIFI_IF_AP;
ESP_ERROR_CHECK(esp_wifi_internal_set_fix_rate(ifx, true, WIFI_PHY_RATE_1M_L));
Users browsing this forum: Google [Bot] and 22 guests
