filipESP wrote: ↑Fri Aug 09, 2019 10:30 am
Hi.
Where I can find the implementation of eg. esp_wifi_start() or other wifi function in ESP-IDF?
I need to know what is the 40U in log: "wifi: ... AID=1, bgn, 40U"
hi
you can use the
search function in github esp-idf
visit the
esp-idf repo
search for esp_wifi_start
and you find example in the
wifi header file
- Screenshot_2019-08-09 espressif esp-idf.png (20.74 KiB) Viewed 5992 times
press to
the line 289 in the search
you find the declare, scroll up
to start the descripton
and you find description of "esp_wifi_start()"
* @brief Start WiFi according to current configuration
* If mode is WIFI_MODE_STA, it create station control block and start station
* If mode is WIFI_MODE_AP, it create soft-AP control block and start soft-AP
* If mode is WIFI_MODE_APSTA, it create soft-AP and station control block and start soft-AP and station
* @return
* - ESP_OK: succeed
* - ESP_ERR_WIFI_NOT_INIT: WiFi is not initialized by esp_wifi_init
* - ESP_ERR_INVALID_ARG: invalid argument
* - ESP_ERR_NO_MEM: out of memory
* - ESP_ERR_WIFI_CONN: WiFi internal error, station or soft-AP control block wrong
* - ESP_FAIL: other WiFi internal errors
esp_err_t esp_wifi_start(void);
it is (void) argument and returns
esp_err_t
also there is
wifi api readme and other info to wifi
for a next question in advance:
yes - there is a
esp wifi lib
yes few implementation are in the lib and config's are done by simple (config_t's*)
what use the lib for init / start / ect..
to answere the second question outside the posttheme:
-> I need to know what is the 40U in log: "wifi: ... AID=1, bgn, 40U"
this is a
ESP_LOG.. Debug Info
example ESP_LOG.. Info, Error.. and so on .. ( *vars..... ) :
"I (13925) wifi: station: xx:xx:xx:xx:xx:xx join, AID=1, bgn, 40U"
Loging info
you find here
seraching for AID
searching
for bgn
brings more and more infos
i am sure you will found the
40U now
and what is mean / response with it, else bump the question..
..further
more search found to relative questions.
hope
this helps
have a look to
detail infos here before
if you ask for
bgn ...it is a
protocoll mode ...
so long
rudi
ps
wifi driver theme
