OTA clarification
Re: OTA clarification
I dont know if you can update factory partition this way, but you can have 2x OTA and no factory partition. This will work for sure.
That's correct. This is the recommended configuration if free space is too limited for a dedicated factory partition.chegewara wrote:I dont know if you can update factory partition this way, but you can have 2x OTA and no factory partition. This will work for sure.
Thank you @chegewara and @ESP_Angus.
I have checked that esp_ota_get_next_update_partition() is not able to point to factory partition.
In order to save more space we are thinking about using a "small" factory where only the OTA process is done and 1 OTA partition which will store the current application.
Using what explained here:
https://esp32.com/viewtopic.php?f=2&t=4 ... ory#p19208
it seems possible to revert from OTA partition to factory. Therefore when we need to upgrade the application, we set factory partition for next boot and then start the OTA process.
The solution you want to use (factory + OTA) is implemented here:
https://github.com/chegewara/esp32-ota-with-ble-setup
Im currently on the OTA part in my project and want to use setup as @davdav (small factory+ single ota) so i read your project and especially the bootloader part.chegewara wrote:The solution you want to use (factory + OTA) is implemented here:
The current version of the bootloader_start.c is 93 lines https://github.com/espressif/esp-idf/bl ... er_start.c where your https://github.com/chegewara/esp32-ota- ... er_start.c is almost 1000.
I didnt find any tutorial or more detailed explanation of the bootloader part.
This is only change in bootloader ive done:
https://esp32.com/viewtopic.php?f=13&t= ... 908#p16328
You can take new bootloader and follow this topic.
You dont even use ForceFactoryBoot in your code. Also, it seems that there is alot additional code in your BL which i cant find in the original(it might be changed?)chegewara wrote:This is only change in bootloader ive done:
Like i said, only part changed in bootloader component is from this topic.
https://github.com/chegewara/esp32-ota- ... #L291-L315
The rest of my code is mix of esp-idf ota example:
https://github.com/espressif/esp-idf/tr ... system/ota
bootwifi from Kolban's repository:
https://github.com/nkolban/esp32-snippe ... g/bootwifi
and my own ble server implementation also based on cpp-utils from Kolban's repository.
Bootloader code was split up into multiple files
https://github.com/espressif/esp-idf/co ... 0435e204d4
Thank you, WiFive! So, now i dont need to copy the bootloader_support folder to the subproject/ too?WiFive wrote:Bootloader code was split up into multiple files
Users browsing this forum: No registered users and 260 guests
