Cannot use debugger when 2 Esp-Wrover-Kit attached to PC
garagegadget
Postby garagegadget » Fri Aug 23, 2019 6:20 am
I recently purchased 2 ESP-Wrover-Kit to facilitate debugging 2 sessions simultaneously using VisualGdb on Windows 10.
The OpenOCD debugger works fine when 1 board is attached at a time.
However,unfortunately this fails to work when 2 boards are simultaneously attached to the PC.
I contacted the Sysprogs who in turn suggested I contact Esprissif.
The reply from Sysprogs:-
"Unfortunately the ESP32-WROVER board does not properly report a unique serial number ("libusb_get_string_descriptor_ascii() failed with LIBUSB_ERROR_INVALID_PARAM" message) and hence OpenOCD cannot select a specific instance of the board by its serial number. Please consider reporting this problem to Espressif and if they provide a fix to OpenOCD that will allow selecting a specific instance of WROVER based on its serial number."
BR,
Brent
Users browsing this forum: No registered users and 100 guests
