mbedtls_ssl_handshake returned -0x7200
filipESP
Postby filipESP » Mon Sep 09, 2019 6:32 am
Hi, I have a problem as below.
I (5141) simple_ota_example: Starting OTA example
I (5141) simple_ota_example: Connected to WiFi network! Attempting to connect to
server...
E (5171) esp-tls: mbedtls_ssl_handshake returned -0x7200
I (5171) esp-tls: Certificate verified.
E (5171) esp-tls: Failed to open new connection
E (5171) TRANS_SSL: Failed to open a new connection
E (5181) HTTP_CLIENT: Connection failed, sock < 0
E (5191) esp_https_ota: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT
E (5191) simple_ota_example: Firmware upgrade failed
filipESP
Re: mbedtls_ssl_handshake returned -0x7200
Postby filipESP » Mon Sep 09, 2019 11:50 am
OK, I resolve my issue but apears next:
E (6981) esp_ota_ops: OTA image has invalid magic byte (expected 0xE9, saw 0x45
E (7001) esp_https_ota: Error: esp_ota_write failed! err=0x0
E (7001) simple_ota_example: Firmware upgrade failed
I can't find any info about this error.
filipESP
Postby filipESP » Mon Sep 09, 2019 2:52 pm
It is getting better but next error is:
I (6786) esp_https_ota: Starting OTA...
I (6786) esp_https_ota: Writing to partition subtype 16 at offset 0x110000
I (6936) esp_https_ota: esp_ota_begin succeeded
I (6936) esp_https_ota: Please Wait. This may take time
I (6966) esp_https_ota: Connection closed, all data received
E (6986) esp_image: invalid segment length 0xffffffff
E (6986) esp_https_ota: Error: esp_ota_end failed! err=0x5379. Image is invalid
E (6986) simple_ota_example: Firmware upgrade failed
filipESP
Postby filipESP » Tue Sep 10, 2019 6:36 am
This expression is true: segment->data_len >= SIXTEEN_MB.
Is inside the verify_segment_header() function (esp_image_format.c file), which return return ESP_ERR_IMAGE_INVALID.
filipESP
Postby filipESP » Tue Sep 10, 2019 2:34 pm
I resolved my problem.
Change version openssl from 1.1.1 to 1.0.2 helped me.
Simon Leung
Postby Simon Leung » Wed Sep 25, 2019 2:54 am
Hi filipESP,
I think I have the same problem as the one you have before. I tried the OpenSSL version 1.0.2j and 1.1.01 And run it under CMD, it doesn't work in my case. Do you mind to provide more information of how you solve your problem please?
Thanks.
Simon Leung
Postby Simon Leung » Thu Sep 26, 2019 4:53 am
Hi filipESP,
How to change version openssl from 1.1.1 to 1.0.2 under msys2?
filipESP
Postby filipESP » Mon Sep 30, 2019 10:37 am
You should to download the older version from openssl website. I don't know how to do it in CMD.
Users browsing this forum: Baidu [Spider], ESP_alisitsyn and 40 guests
