BLE Mesh provisioner switch static OOB
piiiil
Postby piiiil » Wed Sep 18, 2019 9:46 am
i have a setup where i have an ESP32 acting as a BLE mesh provisioner for a number of nodes. All nodes use static OOB as authentication, but each have their own OOB data.
I have tried simply using the provisioner example, and then overwriting the static oob data when in "recv_unprov_adv_pkt" using memcpy, but using this scheme the connection always fails.
It seems that when i call "esp_ble_mesh_init" with the provisioning data, the oob is copied, and can no longer be changed. Is that correct?
piiiil
Re: BLE Mesh provisioner switch static OOB
Postby piiiil » Thu Sep 19, 2019 11:47 am
I know realize that is a question of timing, as i have gotten it to work with a single device.
If device A requests provisioning and i the overwrite the OOB data, and then device B requests provisioning and i again overwrite the OOB data, and then i finally start provisioning device A, I'm of course going to have the wrong OOB data.
My question then becomes: is there a way to to notified (in the prov callback) whenever provisioning of a device starts?
I know of the PROV_LINK_OPEN event, but in that case i don't have the UUID of the device.
Wangcheng
Postby Wangcheng » Mon Nov 25, 2019 1:11 pm
This event don't has device uuid,You can cache uuid before starting the distribution network, at ESP_BLE_MESH_PROVISIONER_RECV_UNPROV_ADK_PKT_EVT.
Users browsing this forum: No registered users and 32 guests
