lwip accept => error 23 (Too many open files in system)
slompf
Postby slompf » Sun Nov 10, 2019 2:02 pm
I'm using lwip to receive data from a remote host. This works fine, but sometimes the connection goes down, so lwip_read returns -1 (error 113, Software caused connection abort). If this happens, I'm closing the socket I read.
After this happens sometimes, accept returns -1 (error 23, Too many open files in system).
Now I'm wondering, what to do to avoid the error of accept. What else but closing the socket can I do?
In order to make clearer what I'm doing, I striped down the logic into this pseudo code:
for (;;)
    fd_set read_fds;
    memcpy(&read_fds, &current_fds, sizeof(read_fds));
    int triggered_nfds = select(highest_socket + 1, &read_fds, NULL, NULL, &timeout);
    if (triggered_nfds > 0) // more than zero sockets have data
        if (FD_ISSET(listen_socket, &read_fds)) // check if listener socket has data
            int socket = accept(listen_socket, (struct sockaddr *)NULL, (socklen_t *)NULL);
            if (socket < 0)
                // log error
                break;
            else
                // set:
                /* 10 second timeout */
                /* enable sending keepalive probes for socket */
                /* 180 sec idle before start sending probes */
                /* 30 sec between probes */
                /* Drop connection after 4 probes without response */
                FD_SET(socket, &current_fds);
                // save connection
        triggered_nfds--;
    for (each accepted connection)
        if (FD_ISSET(connection_socket, &read_fds))
            int recv_size = lwip_read(connection_socket, buffer, buffer_size);
            if(recv_size < 0)
                // log error
                FD_CLR(connection_socket, &current_fds); // clear socket in buffer
                lwip_close(connection_socket);
            }else{
                // do sth with buffer
            triggered_nfds--;
Thanks for your help,
Torsten
ESP_Angus
Re: lwip accept => error 23 (Too many open files in system)
Postby ESP_Angus » Mon Nov 11, 2019 3:36 am
Hi Torsten,
LWIP has a limit of the maximum number of sockets in the system. ENFILE (23) will be returned if this limit is reached:
https://docs.espressif.com/projects/esp ... ax-sockets
The solution may be to either increase this limit in the project config, or fix a socket leak if you're not closing all the accept()-ed sockets - it's hard to see from the pseudocode if they will always be closed.
slompf
Postby slompf » Mon Nov 11, 2019 12:40 pm
Hi
but in general, calling lwip_close after recv returned -1 should be enough to close the socket?
Thanks for your answer,
Torsten
ESP_Angus
Postby ESP_Angus » Tue Nov 12, 2019 3:17 am
Yes, this will close the socket at the ESP32 end. Of course, it only works if recv returns -1 first (ie the other end has closed the socket and isn't holding it open, or some packet loss meant the RST packet was not received yet, etc.)
ESP_Mahavir
Postby ESP_Mahavir » Fri Nov 15, 2019 5:26 am
In case you are using ESP-IDF v3.3 (or prior) release then `lwip_close` won't actually free up socket pcb, you have to use thread safe counterpart API `lwip_close_r` assuming you are using default configuration (https://github.com/espressif/esp-lwip/b ... ets.c#L877).
Ideally you can modify application to use POSIX APIs (i.e. `close` for `lwip_close` and so on), VFS layer in ESP-IDF will do correct translation as provided at https://github.com/espressif/esp-idf/bl ... lwip.c#L61 and thus ensuring appropriate behaviour.
slompf
Postby slompf » Sun Nov 17, 2019 1:55 pm
Thanks for the response. Found an additional explanation here: https://github.com/espressif/esp-idf/pull/537 .
Users browsing this forum: No registered users and 149 guests
