https://docs.espressif.com/projects/esp ... index.html#
but now, when I compile the "hello world" example to flash it in ESP32 module with the male flash command, I have the the error
Andrea@DESKTOP-N00BGML MINGW32 /c/msys32/home/Andrea/esp/hello_world
$ make flash
WARNING: esp-idf git submodule components/asio/asio may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/coap/libcoap may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/libsodium/libsodium may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/lwip/lwip may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/mbedtls/mbedtls may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/mqtt/esp-mqtt may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/nghttp/nghttp2 may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/protobuf-c/protobuf-c may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
WARNING: esp-idf git submodule components/esptool_py/esptool may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
make[1]: *** Nessuna regola per generare l'obiettivo "/home/Andrea/esp/esp-idf/components/esptool_py/esptool/esptool.py", necessario per "/c/msys32/home/Andrea/esp/hello_world/build/bootloader/bootloader.bin". Arresto.
make: *** [/home/Andrea/esp/esp-idf/components/bootloader/Makefile.projbuild:41: /c/msys32/home/Andrea/esp/hello_world/build/bootloader/bootloader.bin] Error 2
