Hello Team,
Followng macros are used in the latest Ethernet Component:
CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET
There are few macros with respect to PHY IC: like
-> CONFIG_EXAMPLE_ETH_PHY_LAN8720
-> CONFIG_EXAMPLE_ETH_PHY_DP83848
I have added New PHY IC and declared CONFIG_EXAMPLE_ETH_PHY_DP83825 .
where are these macros are defined? I am not able to config via Menuconfig.
Kindly help me. where to configure these Macros?
How to include New PHY IC?
Regards
Kumar
ESP-IDF: Ethernet COnfigurations
Re: ESP-IDF: Ethernet COnfigurations
These macros are generated using menuconfig. Why are you unable to use menuconfig?
I am using Menuconfig. But Not able to find a field to make configuration.
Kindly help here.
regards
Narendra
Kindly help here.
regards
Narendra
These options are defined in the Kconfig that comes with the Ethernet projects, for instance examples/ethernet/basic/main/Kconfig.projbuild . Note that the Kconfig text does not have the CONFIG_ prefix, the build system adds that.
- ESP_krzychb
- Contact:
Users browsing this forum: No registered users and 272 guests
