Cannot build WiFi AP example (<property> not defined)
Serg1987
Postby Serg1987 » Sun Apr 05, 2020 3:46 pm
Hello again. This is my second attempt for getting help.
I try to build example from esp-idf :
esp-idf/examples/wifi/getting_started/softAP/
But, it shows me error in line
Error (in WIFI_INIT_CONFIG_DEFAULT()) :
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM not defined;
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM not defined;
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE not defined;
Defined properties are green fonted:
I cannot find where this properties (written above) defined. Nothing anywhere(no it in esp_wifi.h or some others included *.h-files) (besides sdkconfig file, but it's useless)
Is it means that I must modify (define undefined props manually, literally write my own esp-idf v1000.0) instead of using the finished v4.0??? :evil:
ESP_Sprite
Re: Cannot build WiFi AP example (<property> not defined)
Postby ESP_Sprite » Sun Apr 05, 2020 7:44 pm
Those lines normally get dropped in a sdkconfig.h that is generated after you configure the project for the first time. Simply build the project once and that file will exist and the issues should be solved.
Serg1987
Postby Serg1987 » Mon Apr 06, 2020 5:56 am
O, man. Great thanks. ;)
I still included
#include "build/config/sdkconfig.h"
And error dissapeared
Users browsing this forum: Baidu [Spider], ESP_Angus, XHYZN_Marshall and 33 guests
