IDF compiles the firmware into a bin file.
Is it possible to create a hex file to update the firmware?
Thank you.
Create hex file
Re: Create hex file
Can you be a bit more specific than 'to update the firmware'; what do you want to do exactly? Asking because I don't think any tool in our workflow uses hex files.
Re: Create hex file
Nice question I have the same one. Is it possible to flash the esp32 with an hex-file. Actual this only works with bin-files.
But if you want to store an hex-file on your host (PC, ..) you can choose the srec-tool and generate a hex-file.
If you want to flash this file onto your device you can take srec again and do a bin-file from the hex-file.
http://srecord.sourceforge.net/man/man1 ... mples.html
Users browsing this forum: Google Adsense [Bot] and 155 guests
