C:\esp-idf-v4.0.1\examples\Ka-Radio32-master>idf.py build
Checking Python dependencies...
Python requirements from C:\esp-idf-v4.0.1\requirements.txt are satisfied.
Executing action: all (aliases: build)
Running ninja in directory c:\esp-idf-v4.0.1\examples\ka-radio32-master\build
Executing "ninja all"...
[1/686] cmd.exe /C "cd /D C:\esp-idf-v4.0.1\examples\Ka-Ra...*********************************************************"
Partition table binary generated. Contents:
# Espressif ESP32 Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,16K,
otadata,data,ota,0xd000,8K,
phy_init,data,phy,0xf000,4K,
ota_0,app,ota_0,0x10000,1792K,
ota_1,app,ota_1,0x1d0000,1792K,
device,64,0,0x390000,4K,
stations,65,0,0x391000,64K,
device1,66,0,0x3a1000,4K,
hardware,data,nvs,0x3a2000,12K,
[2/686] Building C object esp-idf/app_update/CMakeFiles/__idf_app_update.dir/esp_app_desc.c.obj
FAILED: esp-idf/app_update/CMakeFiles/__idf_app_update.dir/esp_app_desc.c.obj
ccache C:\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -D PROJECT_NAME=\"Ka-Radio32-master\" -DPROJECT_VER=\"\"1.9.7\"\" -Iconfig -I../../../components/app_update/include -I../../../components/newlib/platform_include -I../../../components/freertos/include -I../../../components/heap/include -I../../../components/log/include -I../../../components/soc/esp32/include -I../../../components/soc/include -I../../../components/esp_rom/include -I../../../components/esp_common/include -I../../../components/xtensa/include -I../../../components/xtensa/esp32/include -I../../../components/esp32/include -I../../../components/driver/include -I../../../components/esp_ringbuf/include -I../../../components/esp_event/include -I../../../components/tcpip_adapter/include -I../../../components/lwip/include/apps -I../../../components/lwip/include/apps/sntp -I../../../components/lwip/lwip/src/include -I../../../components/lwip/port/esp32/include -I../../../components/lwip/port/esp32/include/arch -I../../../components/vfs/include -I../../../components/esp_wifi/include -I../../../components/esp_wifi/esp32/include -I../../../components/esp_eth/include -I../../../components/efuse/include -I../../../components/efuse/esp32/include -I../../../components/app_trace/include -I../../../components/spi_flash/include -I../../../components/bootloader_support/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstack-protector -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.0.1-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/app_update/CMakeFiles/__idf_app_update.dir/esp_app_desc.c.obj -MF esp-idf\app_update\CMakeFiles\__idf_app_update.dir\esp_app_desc.c.obj.d -o esp-idf/app_update/CMakeFiles/__idf_app_update.dir/esp_app_desc.c.obj -c C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c
<command-line>: error: too many decimal points in number
C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c:27:16: note: in expansion of macro 'PROJECT_VER'
.version = PROJECT_VER,
<command-line>: error: expected '}' before numeric constant
C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c:22:78: note: to match this '{'
const __attribute__((section(".rodata_desc"))) esp_app_desc_t esp_app_desc = {
C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c:54:23: note: in expansion of macro 'PROJECT_VER'
_Static_assert(sizeof(PROJECT_VER) <= sizeof(esp_app_desc.version), "PROJECT_VER is longer than version field in structure");
<command-line>: error: expected ')' before numeric constant
C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c:54:22: note: to match this '('
[11/686] Building CXX object esp-idf/nvs_flash/CMakeFiles/__idf_nvs_flash.dir/src/nvs_storage.cpp.obj
ninja failed with exit code 1
How to solve this problem? Any clue or solution by members?
Error : C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c too many decimal points in number
Re: Error : C:/esp-idf-v4.0.1/components/app_update/esp_app_desc.c too many decimal points in number
Hi balsub123,
do you have some code which reproduces that problem? What's the IDF version, what sdkconfig file are you using?
Best,
Jakob
Best,
Jakob
Hi Jacob,
Thanks for your reply.
If I exclude PROJECT_VER from firmware image and exclude PROJECT_NAME from firmware image under menuconfig, it's compiling but I get the error message "C:/esp-idf-v4.0.1/components/esp32/cpu_start.c:537: undefined reference to `app_main' " and .bin is not generated. Any solution to this problem?
Thanks.
Regards,
Balsub123
Thanks.
Regards,
Balsub123
Did you define your app_main() function?
If yes, is it defined in a .cpp file?
Best,
Jakob
Best,
Jakob
Yes. I have the function app_main() in app_main .c file.
Sorry, is it a *.c or *.cc/*cpp file? You said yes but said it's defined in a *.c file.
If your app_main() is defined inside a c++ source file, you need to declare it as extern "C" because of C++ name mangling.
Best,
Jakob
Best,
Jakob
Users browsing this forum: Google [Bot] and 234 guests
