hello guys!
I'm trying to combine the esp32 board and an ov2640 camera, i know there's already a new one which is called ESP32-CAM.
but in my project, the distance between the camera and the esp board must not be less than 3 meters, so i have to use wires to connect them like the picture which i attached in the file. I would like to use arduino ide for coding, and I only want the camera to stream as simple as it can.
The main problem is, I can't get any image even i copy somebody's code which can make the camera work. The hardwares he used are also DOIT devkit esp32v1 and ov2640.
The codes i used comes from: https://kobayasitenmei.pixnet.net/blog/ ... -python%29
I also attached the result after I enter the certain IP.
Does anyone face the same problem with me? or who knows how to solved it, help me plz.
thanks a lot
DOIT esp32 devkit v1 problem with ov2640 camera streaming
- the result after using same code
- notstreaming.jpg (105.66 KiB) Viewed 2421 times
- the way i connect my hardware
- hardwareconnect.jpg (4.87 MiB) Viewed 2421 times
Re: DOIT esp32 devkit v1 problem with ov2640 camera streaming
I am experiencing the same issue. Did you ever get this issue resolved? Thanks.
