sdkconfig is missing components
Posted: Wed Jul 22, 2020 1:07 pm
by hbouchard
When I run menuconfig, I'm missing components under the Component config sub-menu. I need to add the Bluetooth component but it isn't there and that not the only one missing. Is there a way to add them all in sdkconfig? Then I could enable/disable them according to my needs.
For info, I'm on latest master release (v4.3-dev-472-gcf056a7d0-dirty). Also, when I created my Eclipse project, I created a project without template if this is of any help.
Hugo
Re: sdkconfig is missing components
Posted: Wed Jul 22, 2020 1:56 pm
by ESP_Roland
Hi Hugo,
Is it possible that you've configured your project for ESP32-S2?
Posted: Wed Jul 22, 2020 2:16 pm
by hbouchard
Thanks for the quick reply!
Actually I just found the solution:
In the main file CMakeLists.txt of my project, I added the following line to speed up compilation time:
set(COMPONENTS freertos bluetooth esptool_py (...) main)
I have commented out this line and now I can see all the components in sdkconfig file. However compile time is longer as all the components are compiled.
Is there a way that I can uncomment the line in CMakeLists.txt file and have the bluetooth component in sdkconfig file?
Hugo
Posted: Thu Jul 23, 2020 8:19 am
by hbouchard
bt was the keywork to use not bluetooth...
set(COMPONENTS freertos bluetooth bt esptool_py (...) main)
Posted: Tue Feb 22, 2022 5:01 pm
by Omgitskillah
Hi Hugo,
Hi, I am configuring for the esp32s2 and I can't see Bluetooth in the components submenu. Did you have a solution for this?
