(solved) re-starting wifi
mzimmers
Postby mzimmers » Mon Jul 27, 2020 11:58 pm
Hi all -
(ESP32, idf v4.0.1)
I'm working on a device that falls back to battery power when it loses line power. When on battery power, it stops Wifi (to save the battery). When an event (like a button push) occurs, it attempts to re-start Wifi. But I get the following error:
esp_wifi_connect() returned error 0x3002.
Which translates to wifi not started. But, it *is* started, at least according to my event handler:
        case WIFI_EVENT_STA_START:
            // step 3.3 in https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/wifi.html
            ESP_LOGI(TAG, "event_handler(): Wifi started at %s.", currentTime.c_str());
            tasks->wifi->setCommsState(WIFI_STATE_STARTED);
            err = esp_wifi_connect();
            if (err == ESP_OK)
                ESP_LOGI(TAG, "event_handler(): esp_wifi_connect() returned successfully.");
            else
                ESP_LOGW(TAG, "event_handler(): esp_wifi_connect() returned error 0x%x.", err);
I (843862) Wifi: event_handler(): Wifi started at Mon Jul 27 16:52:29 2020.
I (843862) Wifi: setCommsState(): changing state to Started.
W (843862) Wifi: event_handler(): esp_wifi_connect() returned error 0x3002.
Am I missing a step in the restart process? I thought I could proceed directly to a connect when started.
Thanks...
istokm
Re: re-starting wifi
Postby istokm » Tue Jul 28, 2020 7:26 am
Strange, that should indeed work. I've got a few ideas that you can look into:
- by chance, is the switch falling through when it shouldn't?
- do you have error checks on the other wifi functions? Just so we are sure there wasn't an error earlier in the chain.
- how did you stop the wifi? just a 'esp_wifi_stop()' call? If so, when did you start it again?
If all of that is as it should be, maybe enable debug logging and see what the wifi driver is actually doing at that moment, I've also come across a event that got fired when it shouldn't: viewtopic.php?f=13&t=16271
mzimmers
Postby mzimmers » Tue Jul 28, 2020 2:22 pm
Highly doubtful.
I do, but I'm wondering what you mean by "earlier in the chain." This is a restart, so I've already called all the init functions. I don't need to call any of them again after a restart, do I?
First a esp_wifi_disconnect(), followed immediately by a esp_wifi_stop(). Time of restart isn't fixed, but it's after I see the message that Wifi has stopped.
Thanks...
istokm
Postby istokm » Wed Jul 29, 2020 11:13 am
Highly doubtful.
What I meant is, I just wanted to make sure it's not something as trivial as a forgotten break - not that the compiler screwed up :D
I personally preffer only calling esp_wifi_stop (as it does both) but it shouldn't cause an issue if they are called synchronously.
Also if you can, try calling esp_wifi_connect sequentially after esp_wifi_start (outside of the start event), as I have a feeling the wifi event loop might be a bit bugged - but can't tell you for sure without them releasing the source.
I have it implemented as such:
esp_err_t err;
err = esp_wifi_start();
if (err != ESP_OK) {
	ESP_LOGE(TAG, "[%s] esp_wifi_start(): %d %s",
   		__func__, err, esp_err_to_name(err));
	return ERR_INTERNAL;
	ESP_LOGE(TAG, "[%s] esp_wifi_connect(): %d %s",
mzimmers
Postby mzimmers » Wed Jul 29, 2020 4:17 pm
Thanks for the suggestions. I do in fact, call esp_wifi_connect() after esp_wifi_start(); it happens on a start event.
I added some code that stops and re-starts wifi if the connect fails; this seems to be working.
            if (err == ESP_OK)
            else
                tasks->wifi->setCommsState(WIFI_STATE_DISCONNECTED);
                esp_wifi_stop(); // this is the new code I added.
                esp_wifi_start(); // this is the new code I added.
I may report back with some additional questions about wake-up, but this particular problem seems to be fixed.
Users browsing this forum: No registered users and 45 guests
