Anyone has reference example for NTC 10K 3950 over ESP32 IDF to measure temperature? It is based on ADC Interface.
Please let me know ASAP if anyone has idea with formula to convert voltage reading to temperature with example as well.
NTC 10k 3950 porting example with ESP32 IDF
Regards,
Ritesh Prajapati
Ritesh Prajapati
Re: NTC 10k 3950 porting example with ESP32 IDF
Hello Espressif Team,
Is there any update regarding query which I have asked into last post?
Regards,
Ritesh Prajapati
Ritesh Prajapati
We have checked with example over ADC but not getting proper value as per expected temperature value.
So, please let me know if anyone has ported successfully of NTC sensor over ADC Interface.
Regards,
Ritesh Prajapati
Ritesh Prajapati
The ESP32's ADC is not very accurate. It needs to be calibrated and averaged to get good readings. See https://docs.espressif.com/projects/esp ... s/adc.html for more information.
Depending on the version and age of the ESP you are using, it might have built in vref or two point calibration. These will help improve the absolute accuracy, but you will still probably need to calibrate to your analog front end and temperature sensor.
Thanks,
Jason
Thanks,
Jason
vonnieda wrote: ↑Fri Sep 04, 2020 7:04 pmThe ESP32's ADC is not very accurate. It needs to be calibrated and averaged to get good readings. See https://docs.espressif.com/projects/esp ... s/adc.html for more information.
Thanks,
Jason
Hello Jason,
Thanks for your quick response.
We are using ESP32 IDF 3.2 Release and ESP-WROOM-32 modules.
Also we are using ADC channel 1 , 12 but and 11 db attenuation for ADC configuration.
Also we have measured at 0 voltage at that time we are getting 142 default ADC reading and with 3.3 voltage we are getting 4995. So, I think for 0 voltage ADC reading should be 0 but why it is giving 142?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: No registered users and 294 guests
