Need help fast switching of PWM
orbitcoms
Postby orbitcoms » Thu Oct 22, 2020 12:02 am
I am working on a project that sends data using 125 kHz signal. So far, I have used LEDC to generate 125kHz signal ok and can switch it on and off using the timer_pause and timer_resume. However, I cannot turn it on an off fast enough without getting watchdog timer errors showing up.
I need to be able to switch the time on and off for bit times of 280us.
My code is below...
#include <stdio.h>
#include "driver/ledc.h"
#include "freertos/freeRTOS.h"
#include "freertos/task.h"
#define PWM_CH0_GPIO (18)
void PWM_Init(void)
  ledc_timer_config_t ledc_timer = {
    .speed_mode = LEDC_HIGH_SPEED_MODE,
    .duty_resolution = LEDC_TIMER_8_BIT,
    .timer_num = LEDC_TIMER_0,
    .freq_hz = 125000,
    .clk_cfg = LEDC_AUTO_CLK
  ledc_timer_config(&ledc_timer);
 ledc_channel_config_t ledc_channel = {
    .gpio_num = PWM_CH0_GPIO,
    .channel = LEDC_CHANNEL_0,
    .intr_type = LEDC_INTR_DISABLE,
    .timer_sel = LEDC_TIMER_0,
    .duty = 127
	ledc_channel_config(&ledc_channel);
void app_main(void)
  printf("Init PWM\n");
  PWM_Init();
  for(;;)
    ledc_timer_pause(LEDC_HIGH_SPEED_MODE,LEDC_TIMER_0);
    vTaskDelay(50/portTICK_PERIOD_MS);
    ledc_timer_resume(LEDC_HIGH_SPEED_MODE,LEDC_TIMER_0);
WiFive
Re: Need help fast switching of PWM
Postby WiFive » Thu Oct 22, 2020 1:29 am
Rmt peripheral has carrier too
orbitcoms
Postby orbitcoms » Thu Oct 22, 2020 2:00 am
Thanks, that peripheral looks like it will do a better job.
Have you used it? I am having trouble assigning the GPIO pin 18 in the config.
The code example does this
 rmt_config_t config = RMT_DEFAULT_CONFIG_TX(CONFIG_EXAMPLE_RMT_TX_GPIO, RMT_TX_CHANNEL);
My code is like this
rmt_config_t config = RMT_DEFAULT_CONFIG_TX(RMT_GPIO, RMT_CHANNEL_0)
Where RMT_GPIO I set as 18
The error I get is "a value of type "int" cannot be used to initialize an entity of type "rmt_config_t"C/C++(144)
ESP_Sprite
Postby ESP_Sprite » Thu Oct 22, 2020 2:18 am
You're using Arduino or C++ to compile this? Possibly you need to do
rmt_config_t config = RMT_DEFAULT_CONFIG_TX((gpio_num_t)RMT_GPIO, RMT_CHANNEL_0)
orbitcoms
Postby orbitcoms » Thu Oct 22, 2020 2:46 am
I am using ESP-IDF in vscode
Users browsing this forum: ESP_Sprite and 17 guests
