Can't install ESP-DIF
LFHeller
Postby LFHeller » Fri Oct 30, 2020 12:10 pm
I've tried a few times to install ESP-IDF but always get this error (taken from the log) near the end of the installation. All the ZIP files are present in the installation directory, it appears that unZIP has failed.
Here are the error details:
2020-10-30 08:49:21.708 Done, exit code=2
2020-10-30 08:49:21.708 --------
2020-10-30 08:49:21.708 Running command: C:\Users\LF Heller\AppData\Local\Temp\is-MFPR6.tmp\7za.exe x -oC:\Users\LF Heller\AppData\Local\Temp\is-MFPR6.tmp -r -aoa "C:\ESP-IDF\.espressif\releases\esp-idf-v4.1.zip"
7-Zip (a) 19.00 (x64) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
Scanning the drive for archives:
ERROR: The system cannot find the file specified.
Heller
System ERROR:
2020-10-30 08:49:21.708 Message box (OK):
Installation has failed with exit code 2
2020-10-30 08:51:15.250 User chose OK.
2020-10-30 08:51:15.260 Message box (Yes/No):
Installation log has been created, it may contain more information about the problem.
Leon
Users browsing this forum: No registered users and 41 guests
