Installation problem
Daniel28972897
Postby Daniel28972897 » Fri Nov 06, 2020 8:09 am
Hi, I am trying to install ESP-IDF but right at the end of it I get this the "Done, exit code=-2" error code, I will post the las part of the intallation log:
2020-11-06 01:42:20.072   --------
2020-11-06 01:42:20.084   Installing Python environment:C:\Users\danie\AppData\Local\Programs\Python\Python38-32\python.exe "C:\esp\esp-idf\tools\idf_tools.py" --idf-path C:\esp\esp-idf install-python-env
2020-11-06 01:42:25.622   Done, exit code=0
2020-11-06 01:42:25.622   --------
2020-11-06 01:42:25.622   Running command: C:\Users\danie\AppData\Local\Programs\Python\Python38-32\python.exe "C:\esp\esp-idf\tools\idf_tools.py" --idf-path C:\esp\esp-idf install-python-env
                          Installing Python packages from C:\esp\esp-idf\requirements.txt
                          Processing c:\esp\esp-idf\tools\kconfig_new\esp-windows-curses
                          Requirement already satisfied: setuptools>=21 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 4)) (50.3.2)
                          Requirement already satisfied: click>=5.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 8)) (7.1.2)
                          Requirement already satisfied: pyserial>=3.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 9)) (3.4)
                          Requirement already satisfied: future>=0.15.2 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 10)) (0.18.2)
                          Requirement already satisfied: cryptography>=2.1.4 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 11)) (3.2.1)
                          Requirement already satisfied: pyparsing<2.4.0,>=2.0.3 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 12)) (2.3.1)
                          Requirement already satisfied: pyelftools>=0.22 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 13)) (0.27)
                          Requirement already satisfied: gdbgui==0.13.2.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 14)) (0.13.2.0)
                          Requirement already satisfied: pygdbmi<=0.9.0.2 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 17)) (0.9.0.2)
                          Requirement already satisfied: reedsolo<=1.5.4,>=1.5.3 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 19)) (1.5.4)
                          Requirement already satisfied: bitstring>=3.1.6 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 20)) (3.1.7)
                          Requirement already satisfied: kconfiglib==13.7.1 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from -r C:\esp\esp-idf\requirements.txt (line 21)) (13.7.1)
                          Requirement already satisfied: windows-curses in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from esp-windows-curses==0.1->-r C:\esp\esp-idf\requirements.txt (line 27)) (2.2.0)
                          Requirement already satisfied: cffi!=1.11.3,>=1.8 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from cryptography>=2.1.4->-r C:\esp\esp-idf\requirements.txt (line 11)) (1.14.3)
                          Requirement already satisfied: six>=1.4.1 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from cryptography>=2.1.4->-r C:\esp\esp-idf\requirements.txt (line 11)) (1.15.0)
                          Requirement already satisfied: Flask<1.0,>=0.12.2 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (0.12.5)
                          Requirement already satisfied: Flask-Compress<2.0,>=1.4.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (1.8.0)
                          Requirement already satisfied: gevent<2.0,>=1.2.2 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (1.5.0)
                          Requirement already satisfied: Pygments<3.0,>=2.2.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (2.7.2)
                          Requirement already satisfied: Flask-SocketIO<3.0,>=2.9 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (2.9.6)
                          Requirement already satisfied: pycparser in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from cffi!=1.11.3,>=1.8->cryptography>=2.1.4->-r C:\esp\esp-idf\requirements.txt (line 11)) (2.20)
                          Requirement already satisfied: Jinja2>=2.4 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (2.11.2)
                          Requirement already satisfied: itsdangerous>=0.21 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (1.1.0)
                          Requirement already satisfied: Werkzeug<1.0,>=0.7 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (0.16.1)
                          Requirement already satisfied: brotli in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Flask-Compress<2.0,>=1.4.0->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (1.0.9)
                          Requirement already satisfied: greenlet>=0.4.14; platform_python_implementation == "CPython" in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from gevent<2.0,>=1.2.2->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (0.4.17)
                          Requirement already satisfied: python-socketio>=1.6.1 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Flask-SocketIO<3.0,>=2.9->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (4.6.0)
                          Requirement already satisfied: MarkupSafe>=0.23 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from Jinja2>=2.4->Flask<1.0,>=0.12.2->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (1.1.1)
                          Requirement already satisfied: python-engineio>=3.13.0 in c:\users\danie\.espressif\python_env\idf4.3_py3.8_env\lib\site-packages (from python-socketio>=1.6.1->Flask-SocketIO<3.0,>=2.9->gdbgui==0.13.2.0->-r C:\esp\esp-idf\requirements.txt (line 14)) (3.13.2)
                          Building wheels for collected packages: esp-windows-curses
                            Building wheel for esp-windows-curses (setup.py): started
                            Building wheel for esp-windows-curses (setup.py): finished with status 'done'
                            Created wheel for esp-windows-curses: filename=esp_windows_curses-0.1-py3-none-any.whl size=1175 sha256=a4d3670b17ac0230ca3298bb6e9287d300e1bce134309fae48f3d3d6947945d7
                            Stored in directory: c:\users\danie\appdata\local\pip\cache\wheels\f8\94\63\5c76ab6f9083cc326ecc247b83f769eb59793f98eff208a41e
                          Successfully built esp-windows-curses
                          Installing collected packages: esp-windows-curses
                            Attempting uninstall: esp-windows-curses
                              Found existing installation: esp-windows-curses 0.1
                              Uninstalling esp-windows-curses-0.1:
                                Successfully uninstalled esp-windows-curses-0.1
                          Successfully installed esp-windows-curses-0.1
2020-11-06 01:42:25.633   CreateShellLink Destination=C:\Users\danie\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ESP-IDF\ESP-IDF Command Prompt (cmd.exe).lnk Description=Open ESP-IDF Command Prompt (cmd.exe) Command=/k ""C:\Users\danie\.espressif\idf_cmd_init.bat" "C:\Users\danie\AppData\Local\Programs\Python\Python38-32\" "C:\Program Files\Git\cmd\""
2020-11-06 01:42:25.642   CreateShellLink Destination=C:\Users\danie\Desktop\ESP-IDF Command Prompt (cmd.exe).lnk Description=Open ESP-IDF Command Prompt (cmd.exe) Command=/k ""C:\Users\danie\.espressif\idf_cmd_init.bat" "C:\Users\danie\AppData\Local\Programs\Python\Python38-32\" "C:\Program Files\Git\cmd\""
2020-11-06 01:42:25.646   Registering IDF Tools executables in Windows Defender: powershell -ExecutionPolicy ByPass -File "C:\Users\danie\.espressif\dist\tools_WD_excl.ps1" -AddExclPath "C:\Users\danie\.espressif\*.exe"
2020-11-06 01:42:25.680   ProcStart failed
2020-11-06 01:42:25.680   Done, exit code=-2
2020-11-06 01:42:25.680   --------
2020-11-06 01:42:25.680   Running command: powershell -ExecutionPolicy ByPass -File "C:\Users\danie\.espressif\dist\tools_WD_excl.ps1" -AddExclPath "C:\Users\danie\.espressif\*.exe"
2020-11-06 01:42:25.680   Message box (OK):
Can anybody tell me please what ProcStart failed and exit code=-2 mean and how to fix it? thank you! :)
Users browsing this forum: Majestic-12 [Bot] and 281 guests
