Just went from Arduino to esp-idf framework. My goal is to send bt-commands for audio control (next track, etc.) to a mobile phone when a pin is high.
I took the a2dp sink demo as basis and reprogrammed some parts. As well set up the sdkconfig.
I commented out the whole part about a2d since I dont rly need it in the end of main.c and can connect to the esp but if i send a command
When I comment it back in the result is it sends the command and causes guru meditation errorBT_BTC: Function btc_avrc_ct_send_passthrough_cmd() called when RC is not connected
main.c:Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4013f382 PS : 0x00060730 A0 : 0x800d2d50 A1 : 0x3ffdd920
A2 : 0x00000000 A3 : 0x3ffdb5b4 A4 : 0x00001000 A5 : 0x3ffdd954
A6 : 0xffffffff A7 : 0x00000000 A8 : 0x3ffd1328 A9 : 0x3ffdd8d0
A10 : 0x00000001 A11 : 0x00000000 A12 : 0x00000001 A13 : 0x00000002
A14 : 0xffffffff A15 : 0x0000143a SAR : 0x00000000 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000018 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
ELF file SHA256: 45d5f21bfd551b14
Backtrace: 0x4013f37f:0x3ffdd920 0x400d2d4d:0x3ffdd950 0x4008e5ad:0x3ffdd980
Rebooting...
// Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "nvs.h"
#include "nvs_flash.h"
#include "esp_system.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "bt_app_core.h"
#include "bt_app_av.h"
#include "esp_bt_main.h"
#include "esp_bt_device.h"
#include "esp_gap_bt_api.h"
#include "esp_a2dp_api.h"
#include "esp_avrc_api.h"
#include "driver/gpio.h"
// OUTPUT Pins
#define GPIO_OUTPUT_IO_0 34
#define GPIO_OUTPUT_IO_1 12
#define GPIO_OUTPUT_PIN_SEL ((1ULL << GPIO_OUTPUT_IO_0) | (1ULL << GPIO_OUTPUT_IO_1))
// INPUT Pins
#define GPIO_INPUT_IO_0 4
#define GPIO_INPUT_IO_1 5
#define GPIO_INPUT_PIN_SEL ((1ULL << GPIO_INPUT_IO_0) | (1ULL << GPIO_INPUT_IO_1))
#define ESP_INTR_FLAG_DEFAULT 0
static xQueueHandle gpio_evt_queue = NULL;
// Fügt isr event dem queue hinzu
static void IRAM_ATTR gpio_isr_handler(void *arg)
// Interrupt sollte keine Funktionen ausführen die nicht im Ram sind!
uint32_t gpio_num = (uint32_t)arg;
xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
/* event for handler "bt_av_hdl_stack_up */
enum
BT_APP_EVT_STACK_UP = 0,
/* handler for bluetooth stack enabled events */
static void bt_av_hdl_stack_evt(uint16_t event, void *p_param);
// Fragt queue nach (isr-)events ab
static void testPinActive(void *arg)
uint32_t io_num;
for (;;)
if (xQueueReceive(gpio_evt_queue, &io_num, portMAX_DELAY))
printf("pin %d aktiv", io_num);
// Siehe sdkconfig.CONFIG_FREERTOS_HZ für portTICK_RATE_MS
vTaskDelay(portTICK_RATE_MS);
esp_err_t err;
if (io_num == 4 || io_num == 5)
err = esp_avrc_ct_send_passthrough_cmd(1, ESP_AVRC_PT_CMD_PLAY, ESP_AVRC_PT_CMD_STATE_PRESSED);
err = esp_avrc_ct_send_passthrough_cmd(1, ESP_AVRC_PT_CMD_PLAY, ESP_AVRC_PT_CMD_STATE_RELEASED);
else
err = esp_avrc_ct_send_passthrough_cmd(1, ESP_AVRC_PT_CMD_PAUSE, ESP_AVRC_PT_CMD_STATE_PRESSED);
err = esp_avrc_ct_send_passthrough_cmd(1, ESP_AVRC_PT_CMD_PAUSE, ESP_AVRC_PT_CMD_STATE_RELEASED);
if (err == ESP_OK)
printf("cmd send");
else
printf("cmd not send: %i", err);
void app_main(void)
/* Initialize NVS — it is used to store PHY calibration data */
esp_err_t err = nvs_flash_init();
if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND)
ESP_ERROR_CHECK(err);
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE));
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
if ((err = esp_bt_controller_init(&bt_cfg)) != ESP_OK)
ESP_LOGE(BT_AV_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(err));
return;
if ((err = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT)) != ESP_OK)
ESP_LOGE(BT_AV_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(err));
return;
if ((err = esp_bluedroid_init()) != ESP_OK)
ESP_LOGE(BT_AV_TAG, "%s initialize bluedroid failed: %s\n", __func__, esp_err_to_name(err));
return;
if ((err = esp_bluedroid_enable()) != ESP_OK)
ESP_LOGE(BT_AV_TAG, "%s enable bluedroid failed: %s\n", __func__, esp_err_to_name(err));
return;
/* create application task */
bt_app_task_start_up();
/* Bluetooth device name, connection mode and profile set up */
bt_app_work_dispatch(bt_av_hdl_stack_evt, BT_APP_EVT_STACK_UP, NULL, 0, NULL);
#if (CONFIG_BT_SSP_ENABLED == true)
/* Set default parameters for Secure Simple Pairing */
esp_bt_sp_param_t param_type = ESP_BT_SP_IOCAP_MODE;
esp_bt_io_cap_t iocap = ESP_BT_IO_CAP_IO;
esp_bt_gap_set_security_param(param_type, &iocap, sizeof(uint8_t));
#endif
* Set default parameters for Legacy Pairing
* Use fixed pin code
esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_FIXED;
esp_bt_pin_code_t pin_code;
pin_code[0] = '1';
pin_code[1] = '2';
pin_code[2] = '3';
pin_code[3] = '4';
esp_bt_gap_set_pin(pin_type, 4, pin_code);
//GPIO
gpio_config_t io_conf;
//interrupt of rising edge
io_conf.intr_type = GPIO_PIN_INTR_POSEDGE;
//bit mask of the pins, use GPIO4/5/TEST here
io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
//set as input mode
io_conf.mode = GPIO_MODE_INPUT;
//enable pull-down mode
io_conf.pull_down_en = 1;
//enable pull-up mode
io_conf.pull_up_en = 0;
gpio_config(&io_conf);
//change gpio intrrupt type for one pin
gpio_set_intr_type(GPIO_INPUT_IO_0, GPIO_INTR_POSEDGE);
gpio_set_intr_type(GPIO_INPUT_IO_1, GPIO_INTR_POSEDGE);
//create a queue to handle gpio event from isr
gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
//start gpio task
//xTaskCreate(gpio_task_example, "gpio_task_example", 2048, NULL, 10, NULL);
xTaskCreate(testPinActive, "testPinActive", 2048, NULL, 10, NULL);
//install gpio isr service
gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
//hook isr handler for specific gpio pin
//gpio_isr_handler_add(GPIO_INPUT_IO_0, gpio_isr_handler, (void*) GPIO_INPUT_IO_0);
gpio_isr_handler_add(GPIO_INPUT_IO_1, gpio_isr_handler, (void *)GPIO_INPUT_IO_1);
//remove isr handler for gpio number.
//gpio_isr_handler_remove(GPIO_INPUT_IO_0);
//hook isr handler for specific gpio pin again
gpio_isr_handler_add(GPIO_INPUT_IO_0, gpio_isr_handler, (void *)GPIO_INPUT_IO_0);
// loop
while (1)
vTaskDelay(10 / portTICK_RATE_MS);
void bt_app_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)
switch (event)
case ESP_BT_GAP_AUTH_CMPL_EVT:
if (param->auth_cmpl.stat == ESP_BT_STATUS_SUCCESS)
ESP_LOGI(BT_AV_TAG, "authentication success: %s", param->auth_cmpl.device_name);
esp_log_buffer_hex(BT_AV_TAG, param->auth_cmpl.bda, ESP_BD_ADDR_LEN);
else
ESP_LOGE(BT_AV_TAG, "authentication failed, status:%d", param->auth_cmpl.stat);
case ESP_BT_GAP_CFM_REQ_EVT:
ESP_LOGI(BT_AV_TAG, "ESP_BT_GAP_CFM_REQ_EVT Please compare the numeric value: %d", param->cfm_req.num_val);
esp_bt_gap_ssp_confirm_reply(param->cfm_req.bda, true);
case ESP_BT_GAP_KEY_NOTIF_EVT:
ESP_LOGI(BT_AV_TAG, "ESP_BT_GAP_KEY_NOTIF_EVT passkey:%d", param->key_notif.passkey);
case ESP_BT_GAP_KEY_REQ_EVT:
ESP_LOGI(BT_AV_TAG, "ESP_BT_GAP_KEY_REQ_EVT Please enter passkey!");
#endif
default:
ESP_LOGI(BT_AV_TAG, "event: %d", event);
return;
ESP_LOGD(BT_AV_TAG, "%s evt %d", __func__, event);
switch (event)
case BT_APP_EVT_STACK_UP:
/* set up device name */
char *dev_name = "TestBla";
esp_bt_dev_set_device_name(dev_name);
esp_bt_gap_register_callback(bt_app_gap_cb);
/* initialize AVRCP controller */
esp_avrc_ct_init();
esp_avrc_ct_register_callback(bt_app_rc_ct_cb);
/* initialize AVRCP target */
assert(esp_avrc_tg_init() == ESP_OK);
esp_avrc_tg_register_callback(bt_app_rc_tg_cb);
esp_avrc_rn_evt_cap_mask_t evt_set = {0};
esp_avrc_rn_evt_bit_mask_operation(ESP_AVRC_BIT_MASK_OP_SET, &evt_set, ESP_AVRC_RN_VOLUME_CHANGE);
assert(esp_avrc_tg_set_rn_evt_cap(&evt_set) == ESP_OK);
/* initialize A2DP sink */
/* esp_a2d_register_callback(&bt_app_a2d_cb);
esp_a2d_sink_register_data_callback(bt_app_a2d_data_cb);
esp_a2d_sink_init(); */
/* set discoverable and connectable mode, wait to be connected */
esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
default:
ESP_LOGE(BT_AV_TAG, "%s unhandled evt %d", __func__, event);
https://pastebin.com/nxNM2aRC
Coming from the java/webapp backend realm I have a hard time understand the concepts of esp-idf and about the bt-world of it. As well, the documentation is lacking in terms of learning it from scratch.
So pls feel free to explain me a bit it you may spare some time.
Cheers
