Single byte (8-bit) write to register GPIO_OUT_REG
kmatch98
Postby kmatch98 » Sun Jan 24, 2021 2:34 am
I'm trying to bitbang a parallel (8080) LCD display using an ESP32-S2 using an 8-bit parallel bus (Saola-Wrover demo board). In writing the code, I'm trying to use the "simple GPIO" method to write to the registers for the GPIOs (see technical manual section 19.3.3 using GPIO_OUT_REG).
Since I want to write 8-bits (single-bytes) to the register, I thought I could make an 8-bit integer pointer to the correct register address and write/read to this single byte. I can successfully write a 32-bit integer to the GPIOs but an 8-bit write doesn't seem to do anything. Also, I cannot perform an 8-bit read properly either.
I see in section 10.3.3 (ESP32-S2 technical manual) that there are conditions where interrrupts occur when writing to this address location (0x3F404004). It is unclear to me whether the chip allows non-aligned reads/writes.
Question: Is there anyway to write a single byte (8-bit) to this GPIO_OUT_REG register? If not, what are best practices for the fastest way to pack the 8-bits into a 32-bit integer and then write them to the register?
Also, perhaps this is related to the following issue on github from the ESP32 IDF. https://github.com/espressif/esp-idf/issues/597
ESP_Sprite
Re: Single byte (8-bit) write to register GPIO_OUT_REG
Postby ESP_Sprite » Sun Jan 24, 2021 3:42 am
There's very few registers in the ESP32 that can be read/written with anything else than 32-bit (UART FIFO comes to mind). GPIO, from what I know, is not one of them. You'll either have to do a read/modify/write or use the w1tc/w1tc registers.
kmatch98
Postby kmatch98 » Sun Jan 24, 2021 3:56 am
Thanks, that’s what I suspected. Thanks for confirming.
Users browsing this forum: No registered users and 64 guests
