I have been trying to write on an encrypted fat partition but I have no success zero bytes are written.
The encrypt option is set to DEVELOPMENT
Have tried esp-idf versions : 4.4-dev 4.3-dev 4.2-stable 4.1.1,
wearleveling is on
I tried also to enable (SPI_FLASH_USE_LEGACY_IMPL) flag on menuconfig.. didnt help
Is there a problem with the fwrite function and encrypted partitions?
partitions.csv line that coresponds to this partition is :
storage, data, fat, 0x3D1000, 0x2F000, encrypted
The code that tries to write to this partition looks like :
// mounting the partition
static esp_err_t mount_data_partition()
ESP_LOGI(TAG, "Mounting FAT data filesystem");
// To mount device we need name of device partition, define base_path
// and allow format partition in case if it is new one and was not formated before
const esp_vfs_fat_mount_config_t mount_config =
.max_files = 4,
.format_if_mount_failed = true,
.allocation_unit_size = CONFIG_WL_SECTOR_SIZE
esp_err_t err;
err = esp_vfs_fat_spiflash_mount(base_path_recs, "storage", &mount_config, &s_wl_handle);
if (err != ESP_OK)
ESP_LOGW(TAG, "Failed to mount path : %s - error : (%s)", base_path_recs, esp_err_to_name(err));
return err;
ESP_LOGI(TAG, "Done mounting %s ", base_path_recs);
return ESP_OK;
// openning the file
FILE *loadTestFile(char *mode)
FILE *file = NULL;
ESP_LOGI(TAG, "Opening file with mode : %s", mode); // mounting is done on another function
file = fopen(TEST_FILE, mode); //
if (file == NULL)
ESP_LOGW(TAG, "Failed to open file");
else
ESP_LOGW(TAG, "File opened correctly");
return file;
void saveToFlash()
char* testString = NULL;
testString = getTestText();
FILE *testFile = loadTestFile("wb"); // W mode..
if (testFile != NULL)
size_t stringLength = strlen(testString);
size_t savedBytes = fwrite(testString, sizeof(char), stringLength, testFile);
ESP_LOGI(TAG, "saveToFlash - string length %d - bytes written : %d", stringLength, savedBytes);
ESP_LOGI(TAG, "saveToFlash - Save to flash finished");
fclose(testFile);
testFile = NULL;
I (934) : Opening file with mode : wb
W (946) : File opened correctly
I (1167) : saveToFlash - string length 1018 - bytes written : 0
I (1167) : saveToFlash - Save to flash finished
W (1525) : unmountRecFilesystem - unmount of /records - error : 0
Thank you for your time
chris
