ESP HTTP/HTTPS server control port?
Doubleu
Postby Doubleu » Sun Sep 26, 2021 12:01 pm
Hi, I have a question according the esp_http_server.h and esp_https_server.h library.
When I create a httpd_config_t struct to configure the server behavior, I can set a so called ctrl_port which has a default value of 32768 (same for http and https server). According to the documentation, this port is used to exchange control signals between different components of the server.
I want to know whether it might pose a security risk to the application or if it is possible to interfere with the server behavior by sending udp packets to port 32768.
httpd_config_t config = {
	.task_priority = tskIDLE_PRIORITY+5,
	.stack_size = 4096,
	.core_id = tskNO_AFFINITY,
	.server_port = 80,
	.ctrl_port = 32768,
ESP_YJM
Re: ESP HTTP/HTTPS server control port?
Postby ESP_YJM » Mon Sep 27, 2021 2:37 am
No, this port binded to link-local address. So only the device itself send control data to this port could be accepted.
Doubleu
Postby Doubleu » Mon Sep 27, 2021 10:25 am
Thank you very much sir for your quick response and for answering my question.
Users browsing this forum: No registered users and 131 guests
