ESP32-C3 RDCYCLE
fabianpedd
ESP32-C3 RDCYCLE
Postby fabianpedd » Tue Feb 22, 2022 8:17 am
How do I access the RISC-V performance counters, namely CYCLE, TIME, and INSTRET on the ESP32-C3 (see Chapter 10 RISC-V spec)? I am running the ESP-IDF.
Running
__asm__ volatile("rdcycle %0" : "=r"(cycles));
or
__asm__ volatile("csrrs %0, cycle, x0" : "=r"(cycles));
results in illegal instruction exceptions. However, they work on other platforms.
Thanks in advance
EDIT: It seems like Espressif decided to implement their own perf counter instead of using the one(s) specified by the RISC-V standard. If you are looking for a register that returns the cycle count, just like
CYCLE
MPCCR
is probably what you are looking for. It is located at
0x7E2
in the CSRs address space and documented under "Performance Counter CSRs (Custom)" in the technical reference manual. There seems to be a C function (not documented in the ESP-IDF for whatever reason) that can be used to read it conveniently from C applications:
esp_cpu_ccount_t esp_cpu_get_ccount(void)
(see here https://github.com/espressif/esp-idf/bl ... _cpu.h#L61).
fabianpedd
Re: ESP32-C3 RDCYCLE
Postby fabianpedd » Tue Mar 08, 2022 7:27 pm
Does anyone have any idea?
Users browsing this forum: Majestic-12 [Bot] and 147 guests
