Ping from ESP32
bobo1974
Re: Ping from ESP32
Postby bobo1974 » Tue Jul 02, 2019 7:20 am
Ok, I ended up solving this rookie mistake.
Had to do with my local implementation of the source files with the arduino ide that I am using.
I found out the real directory that was used, included the file properly and it worked.
thobias
Re: Ping from ESP32
Postby thobias » Tue Jul 23, 2019 5:22 pm
I'm trying to use ping API of ESP8266_RTOS_SDK but there is a problem with ping_init() function, i'm including two libs ping.h and esp_ping.h. The functions of esp_ping are working fine, but the linker do not recognize ping_init of ping.h calling: " undefined reference to `ping_init' " when i try to make the project.
Someone could help me?
fruityTomatoe
Re: Ping from ESP32
Postby fruityTomatoe » Thu Aug 08, 2019 7:45 am
I am also seeing the undefined reference to `ping_init' " issue. Did you have a solution?
mz_autec
Re: Ping from ESP32
Postby mz_autec » Tue Sep 24, 2019 7:46 am
try to include "ping/ping.h".
The ping.h path is not in the compiler paths configuration.
Mirko
nopnop2002
Re: Ping from ESP32
Postby nopnop2002 » Tue Jan 21, 2020 12:43 am
Finally I succeeded in pinging using ESP-IDE.
It is published here.
https://github.com/nopnop2002/esp-idf-ping
Users browsing this forum: Majestic-12 [Bot] and 13 guests
