No heap anymore after adding bluetooth in menuconfig
Re: No heap anymore after adding bluetooth in menuconfig
Ah thats why, I have the ALB32-WROVER. Guess I can use my current breakouts then. Thanks!
Sorry for the post not related to this thread, but as you mentioned that you have ALB32-WROVER, I have an issue with the same module.BuddyCasino wrote:Ah thats why, I have the ALB32-WROVER. Guess I can use my current breakouts then. Thanks!
I canno't exit the deep sleep. Tested with deepsleep example from esp-idf, the module enters deep sleep, but canno't exit it.
I've enabled all wakeup sources, neither of them cannot cause the wakeup from deepsleep.
The same example works without problem on all other boards/modules I have.
Have you ever tested deepsleep on ALB32-WROVER ? Maybe I somehow managed to damage the module (everything else works fine, so it would be quite strange).
Nope, but if you attach test code I'll be happy to run it once that module is soldered.loboris wrote: Have you ever tested deepsleep on ALB32-WROVER ? Maybe I somehow managed to damage the module (everything else works fine, so it would be quite strange).
Thanks. For testing you can use esp-idf/examples/system/deep_sleepBuddyCasino wrote:Nope, but if you attach test code I'll be happy to run it once that module is soldered.
If you are using AnalogLamb breakout board, don't forget to attach pullup resistors to EN & IO0 pins, they are missing on the board...
Users browsing this forum: Majestic-12 [Bot] and 293 guests
