I am attempting to configure GPIO4 and GPIO5 of the ESP32S3 for I2C communication. Based on ESPRESSIF's API, I have written the following code for the I2C set up:
#define MST_TX_BUF_LEN 0
#define MST_RX_BUF_LEN 0
static esp_err_t i2c_conf_master(void) {
i2c_config_t conf = {
.mode = I2C_MODE_MASTER,
.sda_io_num = GPIO_NUM_4,
.scl_io_num = GPIO_NUM_5,
.sda_pullup_en = GPIO_PULLUP_ENABLE,
.scl_pullup_en = GPIO_PULLUP_ENABLE,
.master.clk_speed = 400000
i2c_param_config(I2C_NUM_0, &conf);
return i2c_driver_install(I2C_NUM_0, conf.mode, MST_RX_BUF_LEN, MST_TX_BUF_LEN, 0);
void app_main(void) {
ESP_ERROR_CHECK(i2c_conf_master());
I require a 400kHz clock signal on GPIO5 to interface with another one of my modules, but the signal appears to jump to 3.2V when I probe it. Looks like a bunch of noise with no particular frequency.
Wondering if anyone else has successfully set up their ESP for I2C? I have purchased my devkit from AliExpress and I am not sure if it could be a missing component issue? (GPIO48 was left open and I had to jump it with a bit of solder for the RGB LED to turn on)
ESP32S3 I2C Configuration
Re: ESP32S3 I2C Configuration
Your code doesn't transfer any data over I2C. What do you expect to see on the SCL line in this state?
Users browsing this forum: Baidu [Spider], Bing [Bot], Majestic-12 [Bot] and 177 guests
