- esp_wifi_start()
- esp_wifi_set_config(WIFI_IF_AP, ...)
- esp_wifi_set_mode(WIFI_MODE_AP)
Correct order of API calls to become an access point ...
When looking at the API to become an access point, I see that there are three APIs of interest:
Re: Correct order of API calls to become an access point ...
*bump*
Set mode -> Set config -> Start works fine for me. After starting, I can switch between modes using just esp_wifi_set_mode without needing to touch anything else.
As for a state diagram, I'm not sure, but it would be quite helpful to have one that encompasses everything from start to finish, including when the various events are raised.
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_AP) );
wifi_config_t apConfig = {
.ap = {
.ssid="SomeSSIDHere",
.password = "SomePasswordMoreThan8Chars",
.ssid_len = 0,
.channel = 0,
.authmode = WIFI_AUTH_WPA2_PSK,
.ssid_hidden = 0,
.max_connection = 4, // how many clients to allow?
.beacon_interval = 100 // default value
ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_AP, &apConfig) );
ESP_ERROR_CHECK( esp_wifi_start() );
