Setting mac address and hostname using functions.
My code is this.
I can connect to my Wifi Access point and my http server is working using IP address assigned by DHCP.
I am setting host name using
tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_STA, "mytest");
but I cannot ping it using this name. My DHCP server is windows server.
Another question how can I set mac address as well?
My code is this:
#include "HttpServer.h"
#include "HttpRequest.h"
#include "HttpResponse.h"
#include <Task.h>
#include <WiFi.h>
#include <WiFiEventHandler.h>
#include <tcpip_adapter.h>
#include "esp_log.h"
#include "sdkconfig.h"
extern "C" {
void app_main(void);
static WiFi *wifi;
static void helloWorldHandler(HttpRequest* pRequest, HttpResponse* pResponse)
pResponse->setStatus(HttpResponse::HTTP_STATUS_OK, "OK");
pResponse->addHeader(HttpRequest::HTTP_HEADER_CONTENT_TYPE, "text/plain");
pResponse->sendData("Hello back");
pResponse->close();
class HttpTask: public Task {
void run(void *data) {
ESP_LOGD("http", "Testing http ...");
HttpServer* pHttpServer = new HttpServer();
pHttpServer->addPathHandler(
HttpRequest::HTTP_METHOD_GET,
"/helloWorld",
helloWorldHandler);
pHttpServer->start(80);
return;
static HttpTask *http_task;
class MyWiFiEventHandler: public WiFiEventHandler {
public:
esp_err_t staGotIp(system_event_sta_got_ip_t event_sta_got_ip)
printf("staGotIp\n");
http_task = new HttpTask();
http_task->setStackSize(12000);
http_task->start();
return ESP_OK;
esp_err_t apStart()
printf("apStart\n");
esp_err_t err = tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_STA, "mytest");
printf("tcpip_adapter_set_hostname err=%d\n", err);
return ESP_OK;
void app_main(void)
MyWiFiEventHandler *eventHandler = new MyWiFiEventHandler();
wifi = new WiFi();
wifi->setWifiEventHandler(eventHandler);
vTaskDelay(10000 / portTICK_PERIOD_MS);
bool is_connected = wifi->connectAP("????", "????");
const char * hostname;
err = tcpip_adapter_get_hostname(TCPIP_ADAPTER_IF_STA, &hostname);
//if(err)
printf("tcpip_adapter_get_hostname err=%d, host=%s\n", err, hostname);
test t;
t.execute();
while(1)
printf("is_connected=%d\n", (int)is_connected);
vTaskDelay(100 / portTICK_PERIOD_MS);
Thanks,
Naeem
My code is this.
My code is this:
#include <Task.h>
#include <WiFi.h>
extern "C" {
static WiFi *wifi;
pResponse->close();
"/helloWorld",
helloWorldHandler);
return;
public:
http_task->start();
return ESP_OK;
esp_err_t apStart()
return ESP_OK;
void app_main(void)
wifi = new WiFi();
//if(err)
test t;
t.execute();
while(1)
Thanks,
Naeem
Re: Setting mac address and hostname using functions.
My understanding of name resolution (DNS) is that your device (ESP32) can't declare its own hostname and have that resolved from a remote PC. Imagine I came onto your LAN and declared "MY" DNS name is "passwordServer" .... that would be a horrible situation (I think). Instead, the way DNS works is by having a "database" of hostname to IP address mappings. Some gateways that host their own DNS servers may have "magic" such that when a DHCP IP address is assigned, they have mappings configured at the gateway.
For dynamic DNS there is the concept of "mDNS" which provides a capability for devices to advertise their existence (and identity) for which some PC operating systems can "include" in a DNS search.
This of course then begs the question "What does tcpip_adapter_set_hostname() actually do and when should it be used?" ... I'd love to hear comments on that notion from the community.
// Give our wifi a mac address
uint8_t mac[6] = { 0x10, 0x84, 0x2C, 0x80, 0, 2 };
esp_wifi_set_mac(ESP_IF_WIFI_STA, mac);
Thanks for reply.
I will try setting up mac address for now. Setting hostname was working on our local network for firmwares using keil stack using
Keil function.
https://www.keil.com/pack/doc/mw/Networ ... _func.html
Thanks,
Naeem
Thanks for reply.
Keil function.
Thanks,
Naeem
Yes it is used for dhcp hostname registration which works with some gateways for dns resolution and a common pattern is to use the last 4 digits of the Mac address as a suffix for uniqueness. It is also used for mdns default setting.kolban wrote:My understanding of name resolution (DNS) is that your device (ESP32) can't declare its own hostname and have that resolved from a remote PC. Imagine I came onto your LAN and declared "MY" DNS name is "passwordServer" .... that would be a horrible situation (I think). Instead, the way DNS works is by having a "database" of hostname to IP address mappings. Some gateways that host their own DNS servers may have "magic" such that when a DHCP IP address is assigned, they have mappings configured at the gateway.
I will try setting up mac address.
For Host name.
I think my Wifi network did not support DNS. I will try out on my Ethernet network and will let you know.
Thanks,
Naeem
For Host name.
Thanks,
Naeem
esp_wifi_set_mac is not working for me
see documentation.
https://github.com/espressif/esp-idf/bl ... esp_wifi.h
attention 1. This API can only be called when the interface is disabled
Where to call this function in my example program below. I did try to put before and after connectAP. no luck.
#include <Task.h>
#include <WiFi.h>
#include <test.h>
#include <test2.h>
#include <esp_wifi.h>
extern "C" {
static WiFi *wifi;
pResponse->close();
"/helloWorld",
helloWorldHandler);
return;
public:
http_task->start();
return ESP_OK;
esp_err_t apStart()
return ESP_OK;
void app_main(void)
wifi = new WiFi();
uint8_t mac[6] = { 0x70, 0xB3, 0xD5, 0x6A, 0x02, 0x01 };
esp_err_t err= esp_wifi_set_mac(ESP_IF_WIFI_STA, mac);
printf("esp_wifi_set_mac err=%d\n", err);
//wifi->setIPInfo("192.168.1.200", "192.168.1.254", "255.255.255.0");
bool is_connected = wifi->connectAP(???", "????");
while(1)
see documentation.
#include <Task.h>
#include <WiFi.h>
#include <test.h>
#include <test2.h>
extern "C" {
static WiFi *wifi;
pResponse->close();
"/helloWorld",
helloWorldHandler);
return;
public:
http_task->start();
return ESP_OK;
esp_err_t apStart()
return ESP_OK;
void app_main(void)
wifi = new WiFi();
while(1)
Can anyone answer my last query. where to call function to setup mac address.
Perhaps https://github.com/espressif/esp-idf/tr ... ac_address example might help you?
I don't need to set mac address.
but I do need to set host name to uniquely identify esp32 on my wifi network.
before tcpip_adapter_get_hostname STA err=0, host=espressif
tcpip_adapter_set_hostname with err=0
staGotIp
after tcpip_adapter_get_hostname STA err=0, host=testing
Still cannot ping using host name.
public:
const char * before_hostname;
esp_err_t err = tcpip_adapter_get_hostname(TCPIP_ADAPTER_IF_STA, &before_hostname);
//if(err)
printf("before tcpip_adapter_get_hostname STA err=%d, host=%s\n", err, before_hostname);
err = tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_STA, "testing");
printf("tcpip_adapter_set_hostname with err=%d\n", (int)err);
ACDTRACE(ES_NoError, "staGotIp\n");
main_task = new MainTask();
main_task->setStackSize(12000);
main_task->start();
//if(err)
printf("after tcpip_adapter_get_hostname STA err=%d, host=%s\n", err, hostname);
return ESP_OK;
esp_err_t apStart()
ACDTRACE(ES_NoError, "apStart\n");
return ESP_OK;
staGotIp
public:
//if(err)
main_task->start();
//if(err)
return ESP_OK;
esp_err_t apStart()
return ESP_OK;
Users browsing this forum: Baidu [Spider] and 265 guests
