GATT Client + Simple WiFi Examples
Posted: Thu May 17, 2018 5:06 am
by borch84
Hi I am working on putting together the two examples BLE GATT Client and the Simple Wifi Client. I am just adding libraries definitions and wifi's related function to the gattc client code first. When I compile this code I get the following error:
gatt_client_wifi borch$ make
CC build/main/gattc_wifi.o
In file included from /Users/borch/Documents/Robotica/esp/esp-idf/components/bt/bluedroid/include/bt_target.h:1907:0,
from /Users/borch/Documents/Robotica/esp/esp-idf/components/bt/bluedroid/device/include/controller.h:25,
from /Users/borch/Documents/Robotica/esp/gatt_client_wifi/main/gattc_wifi.c:40:
/Users/borch/Documents/Robotica/esp/esp-idf/components/bt/bluedroid/include/bt_trace.h:28:14: error: expected identifier or '(' before string constant
#define TAG "BT"
/Users/borch/Documents/Robotica/esp/gatt_client_wifi/main/gattc_wifi.c:100:14: note: in expansion of macro 'TAG'
const char *TAG = "simple wifi";
make[1]: *** [gattc_wifi.o] Error 1
make: *** [component-main-build] Error 2
I am not sure why I am getting this error.
The code I am using is this:
*Note: I just included the WIFI section with comments to differentiate between the GATT client code and the simple wifi code.
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
* This file is for gatt client. It can scan ble device, connect one device.
* Run the gatt_server demo, the client demo will automatically connect to the gatt_server demo.
* Client demo will enable gatt_server's notify after connection. Then the two devices will exchange
* data.
#ifndef BTM_INITIAL_TRACE_LEVEL
#define BTM_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef L2CAP_INITIAL_TRACE_LEVEL
#define L2CAP_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef GATT_INITIAL_TRACE_LEVEL
#define GATT_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "controller.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gattc_api.h"
#include "esp_gatt_defs.h"
#include "esp_bt_main.h"
#include "esp_gatt_common_api.h"
//Wifi Section
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define EXAMPLE_ESP_WIFI_MODE_AP   FALSE //TRUE:AP FALSE:STA
#define EXAMPLE_ESP_WIFI_SSID      "dlink"
#define EXAMPLE_ESP_WIFI_PASS      "Pandillero*01"
#define EXAMPLE_MAX_STA_CONN       100
//End Wifi Section
#define GATTC_TAG "GATTC_DEMO"
#define REMOTE_SERVICE_UUID        0x180F //iTAG battery service
#define REMOTE_NOTIFY_CHAR_UUID    0x2A19 //battery level characteristic
#define PROFILE_NUM      1
#define PROFILE_A_APP_ID 0
#define INVALID_HANDLE   0
//static const char remote_device_name[] = "ESP_GATTS_DEMO";
static const char remote_device_name[] = "iTAG"; //borch
static bool connect    = false;
static bool get_server = false;
static esp_gattc_char_elem_t *char_elem_result   = NULL;
static esp_gattc_descr_elem_t *descr_elem_result = NULL;
/* eclare static functions */
static void esp_gap_cb(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param);
static void esp_gattc_cb(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
static void gattc_profile_event_handler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
//Wifi Section
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t wifi_event_group;
/* The event group allows multiple bits for each event,
   but we only care about one event - are we connected
   to the AP with an IP? */
const int WIFI_CONNECTED_BIT = BIT0;
static const char *TAG = "simple wifi";
static esp_err_t event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        esp_wifi_connect();
        break;
    case SYSTEM_EVENT_STA_GOT_IP:
        ESP_LOGI(TAG, "got ip:%s",
                 ip4addr_ntoa(&event->event_info.got_ip.ip_info.ip));
        xEventGroupSetBits(wifi_event_group, WIFI_CONNECTED_BIT);
        break;
    case SYSTEM_EVENT_AP_STACONNECTED:
        ESP_LOGI(TAG, "station:"MACSTR" join, AID=%d",
                 MAC2STR(event->event_info.sta_connected.mac),
                 event->event_info.sta_connected.aid);
        break;
    case SYSTEM_EVENT_AP_STADISCONNECTED:
        ESP_LOGI(TAG, "station:"MACSTR"leave, AID=%d",
                 MAC2STR(event->event_info.sta_disconnected.mac),
                 event->event_info.sta_disconnected.aid);
        break;
    case SYSTEM_EVENT_STA_DISCONNECTED:
        esp_wifi_connect();
        xEventGroupClearBits(wifi_event_group, WIFI_CONNECTED_BIT);
        break;
    default:
        break;
    return ESP_OK;
void wifi_init_softap()
    wifi_event_group = xEventGroupCreate();
    tcpip_adapter_init();
    ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init(&cfg));
    wifi_config_t wifi_config = {
        .ap = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
            .password = EXAMPLE_ESP_WIFI_PASS,
            .max_connection = EXAMPLE_MAX_STA_CONN,
            .authmode = WIFI_AUTH_WPA_WPA2_PSK
    if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
        wifi_config.ap.authmode = WIFI_AUTH_OPEN;
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(TAG, "wifi_init_softap finished.SSID:%s password:%s",
             EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
void wifi_init_sta()
    ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL) );
        .sta = {
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    ESP_LOGI(TAG, "connect to ap SSID:%s password:%s",
//End Wifi Section
static esp_bt_uuid_t remote_filter_service_uuid = {
    .len = ESP_UUID_LEN_16,
    .uuid = {.uuid16 = REMOTE_SERVICE_UUID,},
static esp_bt_uuid_t remote_filter_char_uuid = {
    .uuid = {.uuid16 = REMOTE_NOTIFY_CHAR_UUID,},
static esp_bt_uuid_t notify_descr_uuid = {
    .uuid = {.uuid16 = ESP_GATT_UUID_CHAR_CLIENT_CONFIG,},
static esp_ble_scan_params_t ble_scan_params = {
    .scan_type              = BLE_SCAN_TYPE_ACTIVE,
    .own_addr_type          = BLE_ADDR_TYPE_PUBLIC,
    .scan_filter_policy     = BLE_SCAN_FILTER_ALLOW_ALL,
    .scan_interval          = 0x50,
    .scan_window            = 0x30
struct gattc_profile_inst {
    esp_gattc_cb_t gattc_cb;
    uint16_t gattc_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_start_handle;
    uint16_t service_end_handle;
    uint16_t char_handle;
    esp_bd_addr_t remote_bda;
/* One gatt-based profile one app_id and one gattc_if, this array will store the gattc_if returned by ESP_GATTS_REG_EVT */
static struct gattc_profile_inst gl_profile_tab[PROFILE_NUM] = {
    [PROFILE_A_APP_ID] = {
        .gattc_cb = gattc_profile_event_handler,
        .gattc_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
    esp_ble_gattc_cb_param_t *p_data = (esp_ble_gattc_cb_param_t *)param;
    switch (event) {
    case ESP_GATTC_REG_EVT:
        ESP_LOGI(GATTC_TAG, "REG_EVT");
        esp_err_t scan_ret = esp_ble_gap_set_scan_params(&ble_scan_params);
        if (scan_ret){
            ESP_LOGE(GATTC_TAG, "set scan params error, error code = %x", scan_ret);
        break;
    case ESP_GATTC_CONNECT_EVT:{
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CONNECT_EVT conn_id %d, if %d", p_data->connect.conn_id, gattc_if);
        gl_profile_tab[PROFILE_A_APP_ID].conn_id = p_data->connect.conn_id;
        memcpy(gl_profile_tab[PROFILE_A_APP_ID].remote_bda, p_data->connect.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "REMOTE BDA:");
        esp_log_buffer_hex(GATTC_TAG, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, sizeof(esp_bd_addr_t));
        esp_err_t mtu_ret = esp_ble_gattc_send_mtu_req (gattc_if, p_data->connect.conn_id);
        if (mtu_ret){
            ESP_LOGE(GATTC_TAG, "config MTU error, error code = %x", mtu_ret);
        break;
    case ESP_GATTC_OPEN_EVT:
        if (param->open.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "open failed, status %d", p_data->open.status);
            break;
        ESP_LOGI(GATTC_TAG, "open success");
        break;
    case ESP_GATTC_CFG_MTU_EVT:
        if (param->cfg_mtu.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG,"config mtu failed, error status = %x", param->cfg_mtu.status);
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CFG_MTU_EVT, Status %d, MTU %d, conn_id %d", param->cfg_mtu.status, param->cfg_mtu.mtu, param->cfg_mtu.conn_id);
        esp_ble_gattc_search_service(gattc_if, param->cfg_mtu.conn_id, &remote_filter_service_uuid);
        break;
    case ESP_GATTC_SEARCH_RES_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_RES_EVT");
        esp_gatt_srvc_id_t *srvc_id =(esp_gatt_srvc_id_t *)&p_data->search_res.srvc_id;
        if (srvc_id->id.uuid.len == ESP_UUID_LEN_16 && srvc_id->id.uuid.uuid.uuid16 == REMOTE_SERVICE_UUID) {
            ESP_LOGI(GATTC_TAG, "service found");
            get_server = true;
            gl_profile_tab[PROFILE_A_APP_ID].service_start_handle = p_data->search_res.start_handle;
            gl_profile_tab[PROFILE_A_APP_ID].service_end_handle = p_data->search_res.end_handle;
            ESP_LOGI(GATTC_TAG, "UUID16: %x", srvc_id->id.uuid.uuid.uuid16);
        break;
    case ESP_GATTC_SEARCH_CMPL_EVT:
        if (p_data->search_cmpl.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "search service failed, error status = %x", p_data->search_cmpl.status);
            break;
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_CMPL_EVT");
        if (get_server){
            uint16_t count = 0;
            esp_gatt_status_t status = esp_ble_gattc_get_attr_count( gattc_if,
        p_data->search_cmpl.conn_id,
        ESP_GATT_DB_CHARACTERISTIC,
        gl_profile_tab[PROFILE_A_APP_ID].service_start_handle,
        gl_profile_tab[PROFILE_A_APP_ID].service_end_handle,
        INVALID_HANDLE,
        &count);
            if (status != ESP_GATT_OK){
                ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_attr_count error");
            ESP_LOGI(GATTC_TAG, "attr count: %d\n",count);
            if (count > 0){
                char_elem_result = (esp_gattc_char_elem_t *)malloc(sizeof(esp_gattc_char_elem_t) * count);
                if (!char_elem_result){
                    ESP_LOGE(GATTC_TAG, "gattc no mem");
                }else{
                    status = esp_ble_gattc_get_char_by_uuid( gattc_if,
                                                             remote_filter_char_uuid,
                                                             char_elem_result,
                                                             &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_char_by_uuid error");
                    /*  Every service have only one char in our 'ESP_GATTS_DEMO' demo, so we used first 'char_elem_result' */
                    if (count > 0 && (char_elem_result[0].properties & ESP_GATT_CHAR_PROP_BIT_NOTIFY)){
                        ESP_LOGI(GATTC_TAG, "char count: %d\n",count);
                        gl_profile_tab[PROFILE_A_APP_ID].char_handle = char_elem_result[0].char_handle;
                        esp_ble_gattc_read_char(gattc_if,p_data->search_cmpl.conn_id,gl_profile_tab[PROFILE_A_APP_ID].char_handle,ESP_GATT_AUTH_REQ_NONE);
                        //esp_ble_gattc_register_for_notify (gattc_if, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, char_elem_result[0].char_handle);
                /* free char_elem_result */
                free(char_elem_result);
            }else{
                ESP_LOGE(GATTC_TAG, "no char found");
         break;
    case ESP_GATTC_READ_CHAR_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_READ_CHAR_EVT");
        const char *char_pointer = (char*)p_data->read.value; //p_data->read.value: p_data is pointer of union type esp_ble_gattc_cb_param_t
                                                            //for accesing the read struc we need to use p_data->read.value sintaxis.
        //read member is a struct of type gattc_read_char_evt_param.
        //https://github.com/espressif/esp-idf/blob/a255622/components/bt/bluedroid/api/include/api/esp_gattc_api.h
        //https://stackoverflow.com/questions/16804650/accessing-c-union-members-via-pointers
        //https://www.tutorialspoint.com/cprogramming/c_unions.htm
        // p_data->read.value is a pointer to unit8_t type.
        //We need to convert from *unit8_t to *char https://stackoverflow.com/questions/12296984/c-uint8-datatype-conversion-to-const-char-datatype
        //When we have the pointer to char, we need to cast it int in order to read the numerical value of the iTag.
        //For example, p_data->read.value returns 'c' = 0x63 = 99
        int battery_percentage = (int)*char_pointer;
        ESP_LOGI(GATTC_TAG, "(p_data->read.value) Battery level: %d %%",battery_percentage); //https://stackoverflow.com/questions/1860159/how-to-escape-the-percent-sign-in-cs-printf
        ESP_LOGI(GATTC_TAG, "p_data->read.value_len %d",p_data->read.value_len);
        //int battery_percentage = atoi((const char*) p_data->read.value);
        //int battery_percentage = strtol((const char*)p_data->read.value, NULL, 10);
        //printf("Battery Level: %d ",battery_percentage);
        break;
    case ESP_GATTC_REG_FOR_NOTIFY_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_REG_FOR_NOTIFY_EVT");
        if (p_data->reg_for_notify.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "REG FOR NOTIFY failed: error status = %d", p_data->reg_for_notify.status);
        }else{
            uint16_t count = 0;
            uint16_t notify_en = 1;
            esp_gatt_status_t ret_status = esp_ble_gattc_get_attr_count( gattc_if,
        gl_profile_tab[PROFILE_A_APP_ID].conn_id,
        ESP_GATT_DB_DESCRIPTOR,
        &count);
            if (ret_status != ESP_GATT_OK){
            ESP_LOGI(GATTC_TAG, "desc count: %d\n",count);
            if (count > 0){
                descr_elem_result = malloc(sizeof(esp_gattc_descr_elem_t) * count);
                if (!descr_elem_result){
                    ESP_LOGE(GATTC_TAG, "malloc error, gattc no mem");
                }else{
                    ret_status = esp_ble_gattc_get_descr_by_char_handle( gattc_if,
        p_data->reg_for_notify.handle,
        notify_descr_uuid,
        descr_elem_result,
        &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_descr_by_char_handle error");
                    /* Every char has only one descriptor in our 'ESP_GATTS_DEMO' demo, so we used first 'descr_elem_result' */
                    if (count > 0 && descr_elem_result[0].uuid.len == ESP_UUID_LEN_16 && descr_elem_result[0].uuid.uuid.uuid16 == ESP_GATT_UUID_CHAR_CLIENT_CONFIG){
                        ret_status = esp_ble_gattc_write_char_descr( gattc_if,
        descr_elem_result[0].handle,
        sizeof(notify_en),
        (uint8_t *)&notify_en,
        ESP_GATT_WRITE_TYPE_RSP,
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_write_char_descr error");
                    /* free descr_elem_result */
                    free(descr_elem_result);
            else{
                ESP_LOGE(GATTC_TAG, "decsr not found");
        break;
    case ESP_GATTC_NOTIFY_EVT:
        if (p_data->notify.is_notify){
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive notify value:");
        }else{
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive indicate value:");
        esp_log_buffer_hex(GATTC_TAG, p_data->notify.value, p_data->notify.value_len);
        break;
    case ESP_GATTC_WRITE_DESCR_EVT:
        if (p_data->write.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "write descr failed, error status = %x", p_data->write.status);
            break;
        ESP_LOGI(GATTC_TAG, "write descr success ");
        uint8_t write_char_data[35];
        for (int i = 0; i < sizeof(write_char_data); ++i)
            write_char_data[i] = i % 256;
        esp_ble_gattc_write_char( gattc_if,
                                  sizeof(write_char_data),
                                  write_char_data,
        break;
    case ESP_GATTC_SRVC_CHG_EVT: {
        esp_bd_addr_t bda;
        memcpy(bda, p_data->srvc_chg.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SRVC_CHG_EVT, bd_addr:");
        esp_log_buffer_hex(GATTC_TAG, bda, sizeof(esp_bd_addr_t));
        break;
    case ESP_GATTC_WRITE_CHAR_EVT:
            ESP_LOGE(GATTC_TAG, "write char failed, error status = %x", p_data->write.status);
            break;
        ESP_LOGI(GATTC_TAG, "write char success ");
        break;
    case ESP_GATTC_DISCONNECT_EVT:
        connect = false;
        get_server = false;
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_DISCONNECT_EVT, reason = %d", p_data->disconnect.reason);
        break;
    default:
        break;
    uint8_t *adv_name = NULL;
    uint8_t adv_name_len = 0;
    switch (event) {
    case ESP_GAP_BLE_SCAN_PARAM_SET_COMPLETE_EVT: {
        //the unit of the duration is second
        uint32_t duration = 30;
        esp_ble_gap_start_scanning(duration);
        break;
    case ESP_GAP_BLE_SCAN_START_COMPLETE_EVT:
        //scan start complete event to indicate scan start successfully or failed
        if (param->scan_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
            ESP_LOGE(GATTC_TAG, "scan start failed, error status = %x", param->scan_start_cmpl.status);
            break;
        ESP_LOGI(GATTC_TAG, "scan start success");
        break;
    case ESP_GAP_BLE_SCAN_RESULT_EVT: {
        esp_ble_gap_cb_param_t *scan_result = (esp_ble_gap_cb_param_t *)param;
        switch (scan_result->scan_rst.search_evt) {
        case ESP_GAP_SEARCH_INQ_RES_EVT:
            esp_log_buffer_hex(GATTC_TAG, scan_result->scan_rst.bda, 6);
            ESP_LOGI(GATTC_TAG, "searched Adv Data Len %d, Scan Response Len %d", scan_result->scan_rst.adv_data_len, scan_result->scan_rst.scan_rsp_len);
            adv_name = esp_ble_resolve_adv_data(scan_result->scan_rst.ble_adv,
                                                ESP_BLE_AD_TYPE_NAME_CMPL, &adv_name_len);
            ESP_LOGI(GATTC_TAG, "searched Device Name Len %d", adv_name_len);
            esp_log_buffer_char(GATTC_TAG, adv_name, adv_name_len);
            ESP_LOGI(GATTC_TAG, "\n");
            if (adv_name != NULL) {
                char adv_name_nospaces[strlen(remote_device_name)];
                int i,j;
                for ( i = 0, j = 0; i<strlen((const char*)adv_name);i++,j++) {
                    if (adv_name[i] != ' ')
                        adv_name_nospaces[j]=adv_name[i];
                    else
                        j--;
                adv_name_nospaces[j]=0;
                ESP_LOGI(GATTC_TAG, "remote_device_name: %s | remote_device_name len: %d\n", remote_device_name,strlen(remote_device_name));
                ESP_LOGI(GATTC_TAG, "adv_name_nospaces: %s | adv_name_nospaces len: %d\n", adv_name_nospaces,strlen(adv_name_nospaces));
                //if (strlen(remote_device_name) == adv_name_len && strncmp((char *)adv_name, remote_device_name, adv_name_len) == 0) {
                if ( strncmp(adv_name_nospaces, remote_device_name, strlen(adv_name_nospaces)) == 0 ) {
                    ESP_LOGI(GATTC_TAG, "searched device %s\n", remote_device_name);
                    if (connect == false) {
                        connect = true;
                        ESP_LOGI(GATTC_TAG, "connect to the remote device.");
                        esp_ble_gap_stop_scanning();
                        esp_ble_gattc_open(gl_profile_tab[PROFILE_A_APP_ID].gattc_if, scan_result->scan_rst.bda, scan_result->scan_rst.ble_addr_type, true);
            break;
        case ESP_GAP_SEARCH_INQ_CMPL_EVT:
            break;
        default:
            break;
        break;
    case ESP_GAP_BLE_SCAN_STOP_COMPLETE_EVT:
        if (param->scan_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "scan stop failed, error status = %x", param->scan_stop_cmpl.status);
            break;
        ESP_LOGI(GATTC_TAG, "stop scan successfully");
        break;
    case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
        if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "adv stop failed, error status = %x", param->adv_stop_cmpl.status);
            break;
        ESP_LOGI(GATTC_TAG, "stop adv successfully");
        break;
    case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
         ESP_LOGI(GATTC_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
                  param->update_conn_params.status,
                  param->update_conn_params.min_int,
                  param->update_conn_params.max_int,
                  param->update_conn_params.conn_int,
                  param->update_conn_params.latency,
                  param->update_conn_params.timeout);
        break;
    default:
        break;
    /* If event is register event, store the gattc_if for each profile */
    if (event == ESP_GATTC_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            gl_profile_tab[param->reg.app_id].gattc_if = gattc_if;
        } else {
            ESP_LOGI(GATTC_TAG, "reg app failed, app_id %04x, status %d",
                    param->reg.app_id,
                    param->reg.status);
            return;
    /* If the gattc_if equal to profile A, call profile A cb handler,
     * so here call each profile's callback */
    do {
        int idx;
        for (idx = 0; idx < PROFILE_NUM; idx++) {
            if (gattc_if == ESP_GATT_IF_NONE || /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
                    gattc_if == gl_profile_tab[idx].gattc_if) {
                if (gl_profile_tab[idx].gattc_cb) {
                    gl_profile_tab[idx].gattc_cb(event, gattc_if, param);
    } while (0);
void app_main()
    // Initialize NVS.
    esp_err_t ret = nvs_flash_init();
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
        ESP_ERROR_CHECK(nvs_flash_erase());
    ESP_ERROR_CHECK( ret );
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s init bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    //register the  callback function to the gap module
    ret = esp_ble_gap_register_callback(esp_gap_cb);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gap register failed, error code = %x\n", __func__, ret);
        return;
    //register the callback function to the gattc module
    ret = esp_ble_gattc_register_callback(esp_gattc_cb);
    if(ret){
        ESP_LOGE(GATTC_TAG, "%s gattc register failed, error code = %x\n", __func__, ret);
        return;
    ret = esp_ble_gattc_app_register(PROFILE_A_APP_ID);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gattc app register failed, error code = %x\n", __func__, ret);
    esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
    if (local_mtu_ret){
        ESP_LOGE(GATTC_TAG, "set local  MTU failed, error code = %x", local_mtu_ret);
Re: GATT Client + Simple WiFi Examples
Posted: Thu May 17, 2018 5:08 pm
by kolban
I think youve made a good find here. If we look on the v3.0 code base we find:
https://github.com/espressif/esp-idf/bl ... bt_trace.h
However on the current master, that whole substructure (include downards) is gone.
It is extremely naughty (opinion) for the code to #define a macro called "TAG" especially when it is being used so prevalantly in ESP-IDF programming as a logging variable name.
That said, the macro definition for TAG was made 2 years ago. My recommendation is not to use a variable called TAG in your code but rename it to something else that doesn't collide (eg. MYLOGGING_TAG).
Posted: Fri May 18, 2018 3:42 am
by borch84
kolban wrote:I think youve made a good find here. If we look on the v3.0 code base we find:
Thanks @kolban, I was able to compile the code using another variable name, I wouldn't have imagined that.
