Common source code (ESP-IDF vs Linux)
PaulVdBergh
Postby PaulVdBergh » Fri Jun 01, 2018 10:19 am
In my project I write C++ classes which are 99% identical (at source level) for both linux (RPi) and ESP-IDF. Only minor differences exists, for example ESP_LOGx(...) vs syslog(...).
I'm looking for compile time defines identifying the different compilers, so that this pseudo-code works:
#ifdef RPi
	#define LOG(...) syslog(...)
#elif defined ESP_IDF
	#define LOG(...) ESP_LOGI(...)
#else
	#error "Incompatible code..."
#endif
Thanks in advance,
Paul.
ESP_Sprite
Re: Common source code (ESP-IDF vs Linux)
Postby ESP_Sprite » Sat Jun 02, 2018 8:00 am
ESP-IDF always defines ESP_PLATFORM, so you can use that to see if you're compiling for an Espressif part.
Users browsing this forum: Bing [Bot] and 260 guests
