Hello everybody,
I have been using ESP32 for a research project for a while now. I mostly use the Sniffer API and I'm only using it to sniff management packets. I need to capture as many MGMT packets as possible. Based on my recent findings, if there is a burst of probes from a device (lets say a total of 50 probes in a single channel, and they all look alike), ESP32 only reports one probe out of all of this. So it seems like there is some sort of filtering going on internally. Is there a way to turn this filter off? I need to see all the probes, even if they are exactly the same with just different sequence numbers.
ESP32 Sniffer Burst Sequence
Re: ESP32 Sniffer Burst Sequence
You're possibly better helped by making an issue against esp-idf on Github for this (as a bug or feature request); things like that are usually handled somewhat more structured there.
Users browsing this forum: No registered users and 321 guests
