hi guys
for the meantime or as alternate way for windows designer:
we can design with our loved win IDE's and can compile&link remotly with the VM with Guest System on the Host local or/and world wide from our own ISP / cloud .
the second is, we can update our IoT devices from a list by conneting this devices local in the HomeNetwork, world wide over the connected Internet devices.
the third is for producer, they can use this way for the end inspection and documenting work over fw flashings.
and last but not least, we can work allways same time with espressif's update until the unofficial SDK is updated.
the work is just in time on a new video serie with FULL HD 1080,
you will see the szene with a GUI IDE designed ESP32 Code
pure c code, can be then compiled&linked on local machine with the unofficial SDK and can compiled&linked remotly with the VM / ISP.
and can edit in windows or in linux
the videos get all an better HD update for september release
to do:
build a SSH Server in the VM
build a SSH Client and marked this in your makefile by
create a target "remotly-build" for this
connect it over your IDE new target "remotly-build"
Share before the project Folder
and do a make over the windows project
flash the fw from your share folder to the local devices
and/or send the fw by email / tcp connect to your IoT devices for an auto update....
btw:
.. .. .. you design, build, flash world wide now each connected IoT device on the globe from your central develop suite .. .. ..
allways u2date with the github RTOS / Toolchain
rudi
