How to reduce UART RX Latency
yudopplyr
Postby yudopplyr » Tue Dec 18, 2018 4:33 pm
Hi guys, I am implementing an interrupt handler for reception of data through the UART of the ESP32. Ive measured the response by sending the same data I recieve through the TX output of the UART. The problem is that I want to reduce the current latency time I have (2 ms). Is there any way of getting the UART data at less than 300 microseconds (for a baud rate of 38.4 kbs)?
Note: In general I need to respond to the incoming uart data in less or equal time of 11/baud_rate (which is the duration of sending a uart frame)
  UART Interrupt Example
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "freertos/portmacro.h"
#include "driver/uart.h"
#include "esp_log.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "esp_intr_alloc.h"
#define EX_UART_NUM UART_NUM_1
#define BUF_SIZE (66)
uint8_t rxbuf[BUF_SIZE]; //Buffer for incoming data from UART
const int tx_GPIO = 22;
const int rx_GPIO = 21;
// Both definition are same and valid
//static uart_isr_handle_t *handle_console;
static intr_handle_t handle_console;
static void IRAM_ATTR uart_intr_handle(void *arg)
  uint16_t rx_fifo_len, status;
  status = UART1.int_st.val; // read UART interrupt Status
  rx_fifo_len = UART1.status.rxfifo_cnt; // read number of bytes in UART buffer
  for (int i = 0; i < rx_fifo_len; i++)
    rxbuf[i] = UART1.fifo.rw_byte; // read all bytes
  // after reading bytes from buffer clear UART interrupt status
  uart_clear_intr_status(EX_UART_NUM, UART_RXFIFO_FULL_INT_CLR | UART_RXFIFO_TOUT_INT_CLR);
  //Echo recieved buffer
  uart_write_bytes(EX_UART_NUM, (const char*) rxbuf, rx_fifo_len);
void app_main(void)
  uart_config_t uart_config = {
    .baud_rate = 38400,
    .parity = UART_PARITY_EVEN,
    .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
  ESP_ERROR_CHECK(uart_param_config(EX_UART_NUM, &uart_config));
  //Set UART pins (using UART0 default pins ie no changes.)
  ESP_ERROR_CHECK(uart_set_pin(EX_UART_NUM, tx_GPIO, rx_GPIO, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
  //Install UART driver, and get the queue.
  ESP_ERROR_CHECK(uart_driver_install(EX_UART_NUM, BUF_SIZE * 2, 0, 0, NULL, 0));
  // release the pre registered UART handler/subroutine
  ESP_ERROR_CHECK(uart_isr_free(EX_UART_NUM));
  // register new UART subroutine
  ESP_ERROR_CHECK(uart_isr_register(EX_UART_NUM, uart_intr_handle, NULL, ESP_INTR_FLAG_IRAM, &handle_console));
  // enable RX interrupt
  ESP_ERROR_CHECK(uart_enable_rx_intr(EX_UART_NUM));
  while (1)
    vTaskDelay(1000);
ESP_Sprite
Re: How to reduce UART RX Latency
Postby ESP_Sprite » Wed Dec 19, 2018 2:55 am
I think you're running into the UART receive thresholds. You can configure them differently with uart_intr_config.
yudopplyr
Postby yudopplyr » Thu Dec 20, 2018 3:15 pm
Thanks for the info it worked, I am getting an interrupt after 8 us approx for each byte recieved. For future reference I added this to my code
  uart_intr_config_t uart_intr = {
      .intr_enable_mask = UART_RXFIFO_FULL_INT_ENA_M
                          | UART_RXFIFO_TOUT_INT_ENA_M
                          | UART_FRM_ERR_INT_ENA_M
                          | UART_RXFIFO_OVF_INT_ENA_M
                          | UART_BRK_DET_INT_ENA_M
                          | UART_PARITY_ERR_INT_ENA_M,
      .rxfifo_full_thresh = 1,
      .rx_timeout_thresh = 10,
      .txfifo_empty_intr_thresh = 10
Users browsing this forum: Bing [Bot] and 276 guests
