Hello !
I need to implement that keyboard to that ESP32. The keyboard has USB and I found a USB to RS232 converter.
Should I try and do that or it will be easier to use a Raspberry ?
My ESP board: https://www.olimex.com/Products/IoT/ESP ... e-hardware
The keyboard: https://www.aliexpress.com/item/32319513912.html
The converter: https://www.olimex.com/Products/Modules ... e-hardware
Can I use an USB Keyboard with RS232 on ESP32 ?
Last edited by GeorgeFlorian1 on Fri Feb 21, 2020 10:09 am, edited 1 time in total.
Re: Can I use an USB Keyboard with RS232 on ESP32 ?
This keyboard AND this usb converter as USB device(slave)
Cannot connect to each other
https://electronics.stackexchange.com/q ... and-device
Locate the arduino usb host module ...
So I can't do anything with that keyboard and any ESP32 ?pipi61 wrote: ↑Thu Feb 20, 2020 5:38 pmThis keyboard AND this usb converter as USB device(slave)
find and try PS2 keyboard arduino lib, or find arduino usb host module and library ...
https://www.aliexpress.com/wholesale?ca ... st+arduino
https://www.google.com/search?client=af ... st%20esp32
But why wouldn't the USB to RS232 converter work ? Shouldn't the keyboard send through the serial some signals on key press that I can read using the ESP32 ?pipi61 wrote: ↑Thu Feb 20, 2020 9:57 pmfind and try PS2 keyboard arduino lib, or find arduino usb host module and library ...
Communication only usb host between usb device.
Two usb devices do not communicate with each other
Users browsing this forum: No registered users and 154 guests
