esp32 with W25Q128JV not working
Omri_Sap2020
Postby Omri_Sap2020 » Thu May 13, 2021 12:04 pm
I want to read/write to W25Q128JV through SPI.
I am using this library:
https://github.com/PaulStoffregen/SerialFlash
With an example code(added at the end of message), It works fine with Arduino Nano IoT 33, but with esp32 I can't see the files or write anything to the chip.
It seems to fail on SerialFlash.create() function when returning maxfiles able to write as 0.
Any idea?
This is the example code:
#include <SerialFlash.h>
#include <SPI.h>
const int FlashChipSelect = 4;
void setup(){
  Serial.begin(115200);
  delay(3000);
  Serial.println("SPI Flash");
  if (!SerialFlash.begin(FlashChipSelect)) {
    Serial.println("Unable to access SPI Flash chip");
    while(1){}
void loop(){
  // MAIN MENU
  Serial.println("");
  Serial.println("");
  Serial.println("SerialFlash Read and Write");
  Serial.println("(switch your terminal to no line endings)");
  Serial.println("--------------------------");
  Serial.println("1) Create a new file");
  Serial.println("2) Open a file");
  Serial.println("3) Delete a file");
  Serial.println("Select a number");
  while(!Serial.available()){}
  char choice = Serial.read();
  while(Serial.available()){Serial.read();}
  switch(choice){
    case '1':
      newFile();
      break;
    case '2':
      openFile();
      break;
    case '3':
      deleteFile();
      break;
    default:
      Serial.println("Invalid Selection");
/* Create a new file
 * Request filename up to 20 chars
 * Request a size up to 256 bytes
 * Request some contents
 * Create a file
void newFile(){
  Serial.println("Enter a filename"); // Request filename from user
  while(!Serial.available()){} // Wait for user
  char filename[20] = {}; // buffer to store user filename
  Serial.readBytesUntil(' ', filename, 20);
  Serial.println("Enter a filesize in bytes"); // Request file size from user
  char sizeArray[3] = {}; // buffer to store requested file size
  Serial.readBytesUntil(' ', sizeArray, 3);
  int filesize = atoi(sizeArray); // Convert char array to int (i.e. "40" to 40)
  if(SerialFlash.create(filename, filesize)){ // Returns false if file already exists
    SerialFlashFile file; // Open the file we just created for writing
    file = SerialFlash.open(filename);
    Serial.println("Write some file contents:"); // Request file contents from user
    char contents[256] = {}; // buffer to store file contents
    Serial.readBytesUntil(255, contents, 256);
    while(Serial.available()){Serial.read();} // Empty read buffer
    file.write(contents, filesize); // Write the contents buffer
    Serial.println("");
    Serial.print("New file ");
    Serial.print(filename);
    Serial.print(" created with size ");
    Serial.print(filesize);
    Serial.println(" bytes!");
  }else{
    Serial.println("");
    Serial.println("There was an error creating this file (does it already exist?)");
  return;
/* Open a file
 * Print the directory listing
 * Open file and display contents
void openFile(){
  printDir(); // Function to print the directory listing
  Serial.println("Enter a filename to OPEN"); // Request file name from user
  Serial.println();
  char filename[20] = {}; // buffer to store the file name
  Serial.println(filename);
  file = SerialFlash.open(filename); // open the file
  if (file) {
    Serial.print("File Name: ");
    Serial.println();
    Serial.print("File Size: ");
    Serial.print(file.size());
    Serial.println(" bytes");
    Serial.println();
    Serial.println("File Contents:");
    char buffer[256] = {}; // create a buffer for the file contents
    file.read(buffer, 256); // read file to buffer
    Serial.print(buffer);
  }else{
    Serial.println("File not found!");
  return;
/* Delete a file
 * Delete File
void deleteFile(){
  Serial.println("Enter a filename to DELETE"); // Request file name from user
  char filename[20] = {}; // buffer to store file name
  SerialFlash.remove(filename); // Delete the file
  return;
/* Print Directory
 * Print a list of all files on the chip
 * Stolen from SerialFlash library example "ListFiles"
void printDir(){
  Serial.println("Directory Listing");
  Serial.println("-----------------");
  SerialFlash.opendir();
  while (1) {
    char filename[64];
    uint32_t filesize;
    if (SerialFlash.readdir(filename, sizeof(filename), filesize)) {
      Serial.print("  ");
      spaces(20 - strlen(filename));
      Serial.print("  ");
      Serial.print(" bytes");
      Serial.println();
    } else {
      break; // no more files
void spaces(int num) {
  for (int i=0; i < num; i++) {
    Serial.print(" ");
Omri_Sap2020
Re: esp32 with W25Q128JV not working
Postby Omri_Sap2020 » Tue May 18, 2021 9:29 am
Adding wiring diagram:
ESP32 W25Q128JV
3V3 --------> 3.3V
PIN4 --------> CS
PIN18 --------> CLK
PIN23 --------> DI
PIN19 --------> DO
3V3 --------> WP
3V3 --------> HOLD
GND --------> GND
Thanks!
Users browsing this forum: No registered users and 61 guests
