Send picture over gprs, smtp, softwareSerial, received damaged!!?
wattexi
Postby wattexi » Mon Nov 25, 2019 8:27 pm
ello everyone, I have a problem:
I am trying to send an email attachment with a gsm sim800l module.
I use the AT command, the gmail SMTP server and the softwareSerial lib.
everything is ok, I can send emails, sms, read an html page, send emails with a .txt file as an attachment...
but when I want to send a picture as an attachment, it arrives but degrade : the half of the photo is in good condition but the rest is broken.
the photo is stored in SPIFFS memory, its weight: 1220 bytes, but after transferring his weight: 1235 bytes:
the doc of the sim module says: "AT + SMTPFILE"
first parameter: 2 = binary file
second parameter: <fileName>
third parameter: 1 = "base64"
sim800l.print("AT+SMTPFILE=2,\"photo.jpg\",1\r");
AT+SMTPFT=1220\r"
File file = SPIFFS.open(path_file_attachment);
if(!file)
	Serial.println("// failed to open file for reading");
Serial.println("// read file from spiffs and send...");
while(file.available()>0)
	sim800l.write(file.read());
file.close();
sim800l.print("\"");
I'm stuck, I tried a lot of different things but the picture is still broken ...
I think the problem is maybe the way to send bytes, but I can not do it?
thank you in advance to all those who can help me.
pipi61
Re: Send picture over gprs, smtp, softwareSerial, received damaged!!?
Postby pipi61 » Wed Nov 27, 2019 4:51 pm
Try binary compare the origin with received picture. Check different character, what special character bad or changed to other character(s)
tommeyers
Postby tommeyers » Wed Nov 27, 2019 5:20 pm
I saw one posting:
"Hi, i am trying to send an email with a jpg picture using sim800L. I can send everything but i cant read the received picture. after analyzing the original one i found that the received picture always has before a 0x0A byte, a 0x0D byte.
Example:
original byte sequence:
0x0A, 0xB3, 0xB4
Received sequence:
0x0D, 0x0A, 0xB3, 0xB4
i found that the 0D0A corresponds to the \r\n (CR, carriage return and LF, line feed) so when the original picture as a LF byte the received one will add a CR byte before the LF.
I think the problem is in gsm module but i cant find how to solve that."
You may find something similar when you pick through the data byte by byte.
Tom Meyers
IT Professional, Maker
Santiago, Dominican Republic
wattexi
Postby wattexi » Fri Nov 29, 2019 10:28 am
thank you for your answer I look at this and I come back
special Hello for J-M-L... :shock:
MmQAgTYx
Postby MmQAgTYx » Sun Jan 19, 2020 2:33 pm
Need to set fileType to binary (see AT+SMTPFILE description) and then send file in base64 encoding.
Please provide the full code i need some imagination vor my project. Thank you.
BehicMV
Postby BehicMV » Fri Jun 16, 2023 2:31 pm
I was facing with the similiar problems. Could you help me in this thread?
https://forum.arduino.cc/t/sending-an-i ... 0l/1138658
https://stackoverflow.com/questions/764 ... ending-e-m
http://www.embeddedadvice.com/t/sim-800 ... error/2961
thank you for your attention...
Users browsing this forum: No registered users and 67 guests
