SimpleTime ...and then?
rin67630
Postby rin67630 » Tue Apr 28, 2020 2:23 am
The setup routine of SimpleTime ends with:
  1. //disconnect WiFi as it's no longer needed
  2.   WiFi.disconnect(true);
  3.   WiFi.mode(WIFI_OFF);
Well.
And then?
Wouldn't it have been helpful to give at least the required code to reconnect as a comment?
I am losing hours to "try and error" seeking a way to do that!
tommeyers
Re: SimpleTime ...and then?
Postby tommeyers » Thu Apr 30, 2020 4:40 pm
Have you tried: wifi_on, false?
Have you looked at the .h .c for wifi
Tom
IT Professional, Maker
Santiago, Dominican Republic
rin67630
Postby rin67630 » Thu Apr 30, 2020 7:07 pm
Thank you for replying
I have currently 2 routines:
void disConnect()
//  WiFi.disconnect(); //disconnect WiFi as it's no longer needed (this appear to remove the credentials)
  btStop();
void reConnect()
  WiFi.mode(WIFI_AP);
  WiFi.begin();
  delay(15);
When I run
disConnect();
and immediately after
reConnect();
it works well.
When I run
disConnect();
and 900mS later
reConnect();
as i would need it in the program to save power, it does not reconnect.
I did not try your suggestion:
wifi_on, false?
I never have heared of this option.
What is the purpose of it and the difference with
Where is the useful reference for the WiFi library of the ESP32 describing the procedures?
Thank you.
Laszlo
rin67630
Postby rin67630 » Thu Apr 30, 2020 10:05 pm
I have slightly modified the routines;
void reConnect()
  WiFi.mode(WIFI_STA);
  WiFi.begin();
  while (WiFi.status() != WL_CONNECTED)
    delay(10);
void disConnect()
  //  WiFi.disconnect(); //temporarily disconnect WiFi as it's no longer needed
That way the WiFi functionality is given, but i have got absolutely no power benefit.
With disConnect(), reConnect() or with WiFi always on, I get exactly the same current draw: 125mA, which is really bad.
It is approximately the same consumption than a >10 times more powerful Raspberry Pi zero W running a full fledged Linux a 1GHz.!
Users browsing this forum: No registered users and 75 guests
