I am using ESP32/NOW with Arduino IDE and printing incoming data to the Arduino IDE serial monitor.
Before my data appears, the following is printed on the serial monitor:
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Is there any way to avoid this happening?
How to eliminate serial header?
Re: How to eliminate serial header?
I think those are printed by the ROM... if so, making sure GPIO15 is low on boot (by using e.g. a pulldown resistor) should make it shut up.
Thank you Sprite!
That does indeed work.
Are there any other methods that might do the job?
Not to suppress the output. In theory, another way to skin this (if you have complete control over your hardware) is not to use the default TxD/RxD pins and switch UART0 over to your custom pins as soon as you finished booting. Not 100% sure how you'd do that in the Arduino environment, though.
Thanks again Sprite for you helpful and rapid response !
Users browsing this forum: Google [Bot] and 78 guests
