'hw_timer_t' does not name a type error when in an included file
sorvad
Postby sorvad » Sun Jun 14, 2020 7:48 am
This may be my inexperience but I'm getting a
when declared in an included file. I've stripped the problem down to very simple files. (All using the Arduino IDE for ESP32 Dev Module), if I have this simple file;
hw_timer_t * timer = NULL;
Without any headers etc. then all compiles OK. If I have an included file with it in then fails with the mentioned error. These files below recreate the problem;
The Main
#include "IncludedFile.h"
"IncludedFile.h"
"IncludedFile.cpp"
Now if I take out the #include "IncludedFile.h" from #include "IncludedFile.cpp" then it compiles but then I don't have access to the variable "timer".
I know I'm doing something basic wrong here but what, help appreciated :)
idahowalker
Re: 'hw_timer_t' does not name a type error when in an included file
Postby idahowalker » Sun Jun 14, 2020 9:12 am
In this thread I posted code that uses the hardware timer and other libraries https://esp32.com/viewtopic.php?f=19&t=16109
sorvad
Postby sorvad » Sun Jun 14, 2020 10:23 am
Thanks for that, appreciate you took the time to reply. Your example uses a timer in the main file like my first example above. I can get this to work fine and I've written esp32 timer interrupt code for other projects but the code has always been in the main file. Today I thought I'd keep things a bit tidy and on my latest project I decided to move the code that deals with the interrupts into a separate file that I include and that's when I got the error. I managed to strip it right down to the minimum to repeat the issue, which is what you see in my post.
So it's not quite what I'm looking for but again thanks for replying :)
Users browsing this forum: No registered users and 13 guests
