ESP32 I2C not setting up
Posted: Mon Jun 26, 2017 6:23 pm
by architmuchhal
I am using an ADXL345 sensor with ESP32 on Arduino IDE (1.8.1) The issue I am facing is I2C is not being initialized on the Sparkfun ESP32 Thing.
I used the following pins for I2C on ESP32
SDA - Pin 21
SCL - Pin 22
I have tried the same code with ESP8266 (NodeMCU 1.0) and it works just fine without any issues.
I have also attached the code and if anyone could explain to me why this is happening, it'd be great!
Thanks!
Code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
// ADXL345 I2C address is 0x53(83)
#define Addr 0x53
#define SDA_PIN 21
#define SCL_PIN 22
void setup() {
  Serial.begin(115200);
  Serial.println(" ");
  Serial.println("Serial port initialized ");
  // Initialise I2C communication as MASTER
  Wire.begin(SDA_PIN , SCL_PIN );
  // Start I2C Transmission
  Wire.beginTransmission(Addr);
  // Select bandwidth rate register
  Wire.write(0x2C);
  // Normal mode, Output data rate = 100 Hz
  Wire.write(0x0A);
  // Stop I2C transmission
  Wire.endTransmission();
  // Select power control register
  Wire.write(0x2D);
  // Auto-sleep disable
  Wire.write(0x08);
  // Select data format register
  Wire.write(0x31);
  // Self test disabled, 4-wire interface, Full resolution, Range = +/-2g
  Wire.write(0x08);
  delay(300);
  Serial.println("I2C initialized !");
void loop() {
  readAcclData();
  delay(3000);
void readAcclData()
  unsigned int data[6];
  for (int i = 0; i < 6; i++)
    // Select data register
    Wire.write((50 + i));
    // Request 1 byte of data
    Wire.requestFrom(Addr, 1);
    // Read 6 bytes of data
    // xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
    if (Wire.available() == 1)
      data[i] = Wire.read();
  // Convert the data to 10-bits
  int xAccl = (((data[1] & 0x03) * 256) + data[0]);
  if (xAccl > 511)
    xAccl -= 1024;
  int yAccl = (((data[3] & 0x03) * 256) + data[2]);
  if (yAccl > 511)
    yAccl -= 1024;
  int zAccl = (((data[5] & 0x03) * 256) + data[4]);
  if (zAccl > 511)
    zAccl -= 1024;
  // Output data to serial monitor
  Serial.print("Acceleration in X-Axis is : ");
  Serial.println(xAccl);
  delay(1000);
  Serial.print("Acceleration in Y-Axis is : ");
  Serial.println(yAccl);
  delay(1000);
  Serial.print("Acceleration in Z-Axis is : ");
  Serial.println(zAccl);
  delay(1000);
  Serial.println("Please wait...");
  Serial.println("**********************");
  delay(500);
Serial output:
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:160
load:0x40078000,len:10632
load:0x40080000,len:252
entry 0x40080034
Re: ESP32 I2C not setting up
Posted: Tue Jun 27, 2017 2:23 am
by ESP_Sprite
Moving this to Arduino subforum.
Posted: Sun Jul 02, 2017 3:44 am
by tele_player
Have you tried any other pins?
I just got a Nodemcu 32S a few days ago, and have had success using I2C on 33=SDA, 32= SCL, running an SSD1306 128x64 OLED display.
-Robert
Posted: Mon Jul 03, 2017 1:10 am
by onehorse
Do you have pullups on the I2C bus?
